I've used Setup Project in VS2008 and was very happy with the results. Until, I finally sat to check and nail down every minute error.
Once I started to check, a couple of astonishing error and unhandled exceptions occurred.
Am using primary output source. Am about to leave in an hour to the academy. Need quick help about how to setup project correctly.
Very willing to do it.
Bastard Child of VS2008 - Setup Project - Need Help
Re: Bastard Child of VS2008 - Setup Project - Need Help
I use InstallShield for setups. But I got one member to add an article on VS.Net setup at https://robot.lk/viewtopic.php?f=10&p=1534.
See whether that helps.
Sure, will do.
Thank you.
Thank you.
