How to conver ASCII to Hex using C#
Posted: Fri Dec 20, 2013 1:40 pm
With this little program you can convert an ASCII string to Hex.
Usage:
private static string ConvertToHex(byte[] bytes)
var builder = new StringBuilder();
var hexCharacters = new[] { '0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F' };
for (var i = 0; i < bytes.Length; i++)
int firstValue = (bytes[i] >> 4) & 0x0F;
int secondValue = bytes[i] & 0x0F;
char firstCharacter = hexCharacters[firstValue];
char secondCharacter = hexCharacters[secondValue];
builder.Append("0x");
builder.Append(firstCharacter);
builder.Append(secondCharacter);
builder.Append(' ');
return builder.ToString().Trim(' ');
}Code: Select all
string test = "1234";
ConvertToHex(Encoding.UTF8.GetBytes(test));
