nRF24L01 Module for Arduino
Posted: Wed Jan 29, 2014 11:20 am
by Shehani
If you use a standard Arduino board, you should use the Arduino board’s 3.3V pin?VDD3V3? to provide power. Beacuse the nRF24L01 module is worked at 1.9-3.6V voltage level. Please note, do not use 5V pin(VDD5V) to provide power, which may destroy it.
The Demo pins to Arduino as below:
GND – GND, VCC – 3.3V, CS – D8, CSN – D9, SCK – D10, MOSI – D11, MISO – D12, IRQ – D13
Download the code below into the TX Arduino (transmit) — This code will drive the nRF24L01 module to send out data form 0×00 to 0xFF .
Note, between the write TX_FIFO and clear RX_DR or TX_DS or MAX_RT interrupt flag, would better not serial print anything, which maybe case ACK failed.
void setup()
  SPI_DIR = ( CE + SCK + CSN + MOSI);
  SPI_DIR &=~ ( IRQ + MISO);
  //  attachInterrupt(1, _ISR, LOW);// interrupt enable
  Serial.begin(9600);
  init_io();                        // Initialize IO port
  unsigned char status=SPI_Read(STATUS);
  Serial.print("status = ");
  Serial.println(status,HEX);      // read the mode’s status register, the default value should be ‘E’
  Serial.println("*******************TX_Mode Start****************************");
  TX_Mode();                       // set TX mode
void loop()
  int k = 0;
  for(;;)
    for(int i=0; i<32; i++)
        tx_buf[i] = k++;
    unsigned char status = SPI_Read(STATUS);                // read register STATUS's value
    if(status&TX_DS)                                        // if receive data ready (TX_DS) interrupt
      SPI_RW_Reg(FLUSH_TX,0);
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);     // write playload to TX_FIFO
    if(status&MAX_RT)                                       // this is retransmit than  SETUP_RETR
      SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);     // disable standy-mode
    SPI_RW_Reg(WRITE_REG+STATUS,status);                    // clear RX_DR or TX_DS or MAX_RT interrupt flag
    delay(1000);
Download the code below into the RX Arduino (receive) – This code will drive the nFR24L01 module to receive the data that transmit form the TX module and print it to serial port.
Note, clear RX_FIFO must bellow Read_FIFO
void setup()
  //  attachInterrupt(1, _ISR, LOW); // interrupt enable
  Serial.begin(9600);
  Serial.println("*****************RX_Mode start******************************R");
  RX_Mode();                        // set RX mode
void loop()
  for(;;)
    if(status&RX_DR)                                        // if receive data ready (TX_DS) interrupt
      SPI_Read_Buf(RD_RX_PLOAD, rx_buf, TX_PLOAD_WIDTH);    // read playload to rx_buf
      SPI_RW_Reg(FLUSH_RX,0);                               // clear RX_FIFO
          Serial.print(" ");
          Serial.print(rx_buf[i],HEX);                      // print rx_buf
      Serial.println(" ");
    SPI_RW_Reg(WRITE_REG+STATUS,status);                    // clear RX_DR/TX_DS/MAX_RT interrupt flag
    delay(1000);
Now power on both Arduino , and connect the RX one to PC via USB. Open the IDE serial port monitor , change the baud rate to 9600 bps , and you can see the data that received.
If you want to change Arduino pin connecting to module , just modify the define on the NRF24L01.h .
All the project here(include API.h and NRF24L01.h)
nRF24L01_Demo_For_Arduino.zip
(7.61 KiB) Downloaded 1563 times
Download nRF24L01_Demo_For_Arduino.
nRF24L01_Demo_For_Arduino_v1.1.zip
(7.37 KiB) Downloaded 1576 times
Download nRF24L01_Demo_For_Arduino_v1.1.
nRF24L01 with Arduinio’s SPI Library
Article courtesy of elecfreaks.com
