Page 1 of 2
SINHALA and J2ME
Posted: Wed Mar 24, 2010 12:00 pm
by Rksk
How to create j2me application with ability to type in sinhala letters?
like THILINA DICTIONARY , THIBASme SMS
Re: SINHALA and J2ME
Posted: Wed Mar 24, 2010 12:44 pm
See
How to use a different font in J2ME if you want to change to a font that the phone supports. As we know that Sinhala isn't usually installed with phones, this is not easily possible.
You'll have to move to embedded way of displaying fonts. If I clarify a bit, you can do the necessary graphics for your own customised fonts and save that as an image file along with your other graphic images. After that you could use those customised fonts where ever you want in the app. For ex: first of all you have to create a PNG image strip with all the characters say
1234..... ABCD....abcd... and so on in your desired style.
You can use setClip() to set the clipping position on the strip (PNG image with fonts) and then draw the image using drawImage();. Note that PNG can have colourless pixels so it overlays nicely to the background.
See
Mobile Bit Font Creator that might help you straight away.
Hope that helps!
Posted: Wed Mar 24, 2010 6:28 pm
by Rksk
See this image! open with paint.
I found this in THILINA DICTIONARY.
But in THIBASme SMS it draws all the charactors sinhala, tamil also english.
- font.png (4.44 KiB) Viewed 15517 times
Posted: Wed Mar 24, 2010 6:33 pm
I think there should be several images of this kind
Posted: Wed Mar 24, 2010 6:55 pm
by Rksk
Posted: Wed Mar 24, 2010 7:08 pm
Looks like a pixel map to me ?
Posted: Wed Mar 24, 2010 7:16 pm
by Rksk
What is a pixel map?
Posted: Wed Mar 24, 2010 7:22 pm
I will give you a little example...
000010000
000101000
000111000
001000100
010000010
Can you see letter A is there? 0's represent blank area and 1's represent letter foreground.
Now you can represent this as an array as follows.
array_A = {0,0,0,0,1,0,0,0,0, 0,0,0,1,0,1,0,0,0, ...............
When you add several fonts to a single array like this, it is usually referred as a simple pixel map.
Posted: Tue Mar 30, 2010 6:39 pm
by Rksk
Pls give an example on setclip() with the above posted PNG or another.
Neo wrote:See
See
Posted: Tue Mar 30, 2010 8:26 pm
See
http://devlinslab.blogspot.com/2007/11/ ... -part.html
This is a great article that demonstrate exactly the same thing you want.
