Syntax
The syntax of Java is largely derived from C++. Unlike C++, which combines the syntax for structured, generic, and object-oriented programming, Java was built almost exclusively as an object-oriented language. All code is written inside a class, and everything is an object, with the exception of the primitive data types (integers, floating-point numbers, Boolean values, and characters), which are not classes for performance reasons.
Unlike C++, Java does not support operator overloading or multiple inheritance for classes. This simplifies the language and aids in preventing potential errors and anti-pattern design.
Java uses similar commenting methods to C++. There are three different styles of comments: a single line style marked with two slashes (//), a multiple line style opened with /* and closed with */, and the Javadoc commenting style opened with /** and closed with */. The Javadoc style of commenting allows the user to run the Javadoc executable to compile documentation for the program.
Example:
// This is an example of a single line comment using two slashes
/* This is an example of a multiple line comment using the slash and asterisk.
This type of comment can be used to hold a lot of information or deactivate
code but it is very important to remember to close the comment. */
* This is an example of a Javadoc comment; Javadoc can compile documentation
* from this text.
Hello world
The traditional Hello world program can be written in Java as:
class HelloWorldApp {
public static void main(String[] args) {
System.out.println("Hello World!"); // Display the string.
}Source files must be named after the public class they contain, appending the suffix .java, for example, HelloWorldApp.java. It must first be compiled into byte code, using a Java compiler, producing a file named HelloWorldApp.class. Only then can it be executed, or 'launched'. The Java source file may only contain one public class but can contain multiple classes with less than public access and any number of public inner classes.
A class that is not declared public may be stored in any .java file. The compiler will generate a class file for each class defined in the source file. The name of the class file is the name of the class, with .class appended. For class file generation, anonymous classes are treated as if their name were the concatenation of the name of their enclosing class, a $, and an integer.
The keyword public denotes that a method can be called from code in other classes, or that a class may be used by classes outside the class hierarchy. The class hierarchy is related to the name of the directory in which the .java file is located.
The keyword static in front of a method indicates a static method, which is associated only with the class and not with any specific instance of that class. Only static methods can be invoked without a reference to an object. Static methods cannot access any class members that are not also static.
The keyword void indicates that the main method does not return any value to the caller. If a Java program is to exit with an error code, it must call System.exit () explicitly.
The method name "main" is not a keyword in the Java language. It is simply the name of the method the Java launcher calls to pass control to the program. Java classes that run in managed environments such as applets and Enterprise JavaBeans do not use or need a main() method. A Java program may contain multiple classes that have main methods, which means that the VM needs to be explicitly told which class to launch from.
The main method must accept an array of String objects. By convention, it is referenced as args although any other legal identifier name can be used. Since Java 5, the main method can also use variable arguments, in the form of public static void main(String... args), allowing the main method to be invoked with an arbitrary number of String arguments. The effect of this alternate declaration is semantically identical (the args parameter is still an array of String objects), but allows an alternative syntax for creating and passing the array.
The Java launcher launches Java by loading a given class (specified on the command line or as an attribute in a JAR) and starting its public static void main(String[]) method. Stand-alone programs must declare this method explicitly. The String [] args parameter is an array of String objects containing any arguments passed to the class. The parameters to main are often passed by means of a command line.
Printing is part of a Java standard library: The System class defines a public static field called out. The out object is an instance of the Print Stream class and provides many methods for printing data to standard out, including printing (String) which also appends a new line to the passed string.
The string "Hello, world!" is automatically converted to a String object by the compiler.
N:B: See more-ava Programming History Part-5/6
