Description of code:
toBinaryString(int in):
This is the method that takes an integer type value and returns the string representation of unsigned integer value that will represent the data in binary (base 2).
toHexString(int in):
This is the method that takes an integer type value and converts in hexadecimal or in an unsigned integer (base 16).
toOctalString(int in):
This is the method that takes an integer type value and converts it into octal type data. The octal type data has base 8.
public class DataConversion{
public static void main(String[] args) {
System.out.println("Data types conversion example!");
int in = 243;
System.out.println("Integer: " + in);
//integer to binary
String by = Integer.toBinaryString(in);
System.out.println("Byte: " + by);
//integer to hexadecimal
String hex = Integer.toHexString(in);
System.out.println("Hexa decimal: " + hex);
//integer to octal
String oct = Integer.toOctalString(in);
System.out.println("Octal: " + oct);
