using System;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Shapes;
namespace Silverlight_WavelengthToColor
public partial class MainPage : UserControl
private const double point1Y = -200.00;
private const double point2Y = +400.00;
private const double point3Y = +100.00;
public MainPage()
InitializeComponent();
this.Loaded += new RoutedEventHandler(MainPage_Loaded);
void MainPage_Loaded(object sender, RoutedEventArgs e)
this.trackBar1.ValueChanged +=
new RoutedPropertyChangedEventHandler
<double>(trackBar1_ValueChanged);
void trackBar1_ValueChanged(object sender,
RoutedPropertyChangedEventArgs<double> e)
//minimum wavelnegth is 350nm which should display 2.2 waves.
double slidefactor = (this.trackBar1.Value/3)/2;
this.spline1.Points = new PointCollection(){
new Point(slidefactor * 1, point1Y),
new Point(slidefactor * 2, point2Y),
new Point(slidefactor * 3, point3Y),
new Point(slidefactor * 4, point1Y),
new Point(slidefactor * 5, point2Y),
new Point(slidefactor * 6, point3Y),
new Point(slidefactor * 7, point1Y),
new Point(slidefactor * 8, point2Y),
new Point(slidefactor * 9, point3Y)
this.panel1.Fill = new SolidColorBrush(
this.getColorFromWaveLength((int)e.NewValue));
this.labelCurrentWaveLength.Text =
this.trackBar1.Value.ToString("000.00") + " nm";
this.labelR.Text = "R: " +
((Color)getColorFromWaveLength((int)e.NewValue)).R.ToString();
this.labelG.Text = "G: " +
((Color)getColorFromWaveLength((int)e.NewValue)).G.ToString();
this.labelB.Text = "B: " +
((Color)getColorFromWaveLength((int)e.NewValue)).B.ToString();
private Color getColorFromWaveLength(int Wavelength)
double Gamma = 1.00;
int IntensityMax = 255;
double Blue;
double Green;
double Red;
double Factor;
if (Wavelength >= 350 && Wavelength <= 439)
Red = -(Wavelength - 440d) / (440d - 350d);
Green = 0.0;
Blue = 1.0;
else if (Wavelength >= 440 && Wavelength <= 489)
Red = 0.0;
Green = (Wavelength - 440d) / (490d - 440d);
Blue = 1.0;
else if (Wavelength >= 490 && Wavelength <= 509)
Red = 0.0;
Green = 1.0;
Blue = -(Wavelength - 510d) / (510d - 490d);
else if (Wavelength >= 510 && Wavelength <= 579)
Red = (Wavelength - 510d) / (580d - 510d);
Green = 1.0;
Blue = 0.0;
else if (Wavelength >= 580 && Wavelength <= 644)
Red = 1.0;
Green = -(Wavelength - 645d) / (645d - 580d);
Blue = 0.0;
else if (Wavelength >= 645 && Wavelength <= 780)
Red = 1.0;
Green = 0.0;
Blue = 0.0;
else
Red = 0.0;
Green = 0.0;
Blue = 0.0;
if (Wavelength >= 350 && Wavelength <= 419)
Factor = 0.3 + 0.7 * (Wavelength - 350d) / (420d - 350d);
else if (Wavelength >= 420 && Wavelength <= 700)
Factor = 1.0;
else if (Wavelength >= 701 && Wavelength <= 780)
Factor = 0.3 + 0.7 * (780d - Wavelength) / (780d - 700d);
else
Factor = 0.0;
byte A = 255;
byte R = (byte)this.factorAdjust(
Red, Factor, IntensityMax, Gamma);
byte G = (byte)this.factorAdjust(
Green, Factor, IntensityMax, Gamma);
byte B = (byte)this.factorAdjust(
Blue, Factor, IntensityMax, Gamma);
return Color.FromArgb(A ,R, G, B);
private int factorAdjust( double Color,
double Factor,
int IntensityMax,
double Gamma)
if (Color == 0.0)
return 0;
else
return (int)Math.Round(
IntensityMax * Math.Pow(Color * Factor, Gamma));
<UserControl x:Class="Silverlight_WavelengthToColor.MainPage"
xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
mc:Ignorable="d" d:DesignWidth="400" d:DesignHeight="300">
<Canvas x:Name="LayoutRoot" Width="400" Height="300" Background="#EDF1F2">
<Slider x:Name="trackBar1" MaxWidth="384" Minimum="350" Maximum="780"
Width="390" Height="20" Canvas.Top="11" Value="780" Canvas.Left="8"/>
<TextBlock x:Name="labelCurrentWaveLength" Canvas.Left="285" Canvas.Top="35"
Text="780.00 nm" TextWrapping="Wrap" FontSize="18.667" FontWeight="Bold" HorizontalAlignment="Right" VerticalAlignment="Bottom"/>
<Canvas Height="16" Width="389" Canvas.Top="76" Opacity="0.5" Canvas.Left="9">
<TextBlock Height="16" Width="40" Canvas.Left="175" Text="780nm"
TextWrapping="Wrap" RenderTransformOrigin="0.625,0.25"/>
<Path Fill="White" Stretch="Fill" Stroke="Black" Height="1" Width="169" UseLayoutRounding="False" Canvas.Left="219" Canvas.Top="7" Data="M248,80 L391.75345,80"/>
<Path Fill="White" Stretch="Fill" Stroke="Black" Height="8" Width="1" UseLayoutRounding="False" Canvas.Left="388" Canvas.Top="3.457" Data="M392,76 L392,88.023605"/>
<Path Fill="White" Stretch="Fill" Stroke="Black" Height="1" Width="171" UseLayoutRounding="False" Canvas.Left="0" Canvas.Top="7" Data="M248,80 L391.75345,80"/>
<Path Fill="White" Stretch="Fill" Stroke="Black" Height="8" Width="1" UseLayoutRounding="False" Canvas.Left="0" Canvas.Top="3.457" Data="M392,76 L392,88.023605"/>
</Canvas>
<Canvas x:Name="CanvasSplineBackground" Width="390" Height="200" Canvas.Left="8" Canvas.Top="92">
<Rectangle x:Name="panel1" Width="390" Height="200" Fill="Red" Opacity="0.3" Stroke="Black" StrokeThickness="1" Canvas.Left="0"/>
<Rectangle x:Name="panel2" Width="390" Height="200" Fill="Transparent" Stroke="Black" StrokeThickness="1" Canvas.Left="0"/>
<Path Fill="Black" Stretch="Fill" Stroke="Black" StrokeThickness="1" Height="1" Width="390" UseLayoutRounding="False" Canvas.Left="0" Canvas.Top="100" Data="M72,192 L392,192"/>
<Path Fill="Black" Stretch="Fill" Stroke="Black" StrokeThickness="1" Height="200" Width="1" UseLayoutRounding="False" Canvas.Top="0" Data="M232,88 L232,292" Canvas.Left="195"/>
</Canvas>
<Canvas x:Name="CanvasSpline" Width="390" Height="200" Canvas.Left="8" Canvas.Top="92" >
<Canvas.Clip>
<RectangleGeometry Rect="0, 0, 390, 200"/>
</Canvas.Clip>
<Path Stroke="Black" StrokeThickness="2" >
<Path.Data>
<PathGeometry>
<PathGeometry.Figures>
<PathFigureCollection>
<PathFigure StartPoint="0,100">
<PathFigure.Segments>
<PathSegmentCollection>
<PolyBezierSegment x:Name="spline1" Points=" 130,-200 260,400 390,100
520,-200 650,400 780,100
910,-200 1040,400 1270,100 "></PolyBezierSegment>
</PathSegmentCollection>
</PathFigure.Segments>
</PathFigure>
</PathFigureCollection>
</PathGeometry.Figures>
</PathGeometry>
</Path.Data>
</Path>
<Path Stroke="Black" StrokeThickness="2" Opacity="0.1">
<Path.Data>
<PathGeometry>
<PolyBezierSegment x:Name="spline350" Points=" 58.3333333,-200 116.666667,400 175,100
233.333333,-200 291.666667,400 350,100
408.333333,-200 466.666666,400 525,100 "></PolyBezierSegment>
</PathFigure>
</PathGeometry>
</Path.Data>
</Path>
<Path.Data>
<PathGeometry>
<PolyBezierSegment x:Name="spline780" Points=" 130,-200 260,400 390,100
</PathFigure>
</PathGeometry>
</Path.Data>
</Path>
</Canvas>
<TextBlock x:Name="labelR" Text="R: 76" TextWrapping="Wrap" FontSize="16" FontWeight="Bold" Canvas.Left="9" Canvas.Top="49" d:LayoutOverrides="HorizontalMargin"/>
<TextBlock x:Name="labelG" Text="G: 0" TextWrapping="Wrap" FontSize="16" FontWeight="Bold" Canvas.Left="85" Canvas.Top="49" d:LayoutOverrides="HorizontalMargin"/>
<TextBlock x:Name="labelB" Text="B: 76" TextWrapping="Wrap" FontSize="16" FontWeight="Bold" Canvas.Left="161" Canvas.Top="49"/>
</Canvas>
</UserControl>
