Coding by tweaking on-screen shapes and drawings could revolutionise computer programming, making it accessible to all
MANY great ideas start out as scribbles on scraps of paper, as thinking visually is an intuitive way to grapple with abstract concepts. Part of the reason is the immediacy - thoughts can be captured and communicated in a sketch and, if wrong, changed or scratched out just as quickly. Not so for computer programmers.
A program is a set of instructions for turning input - such as numerical values - into output. The causal chain is one-way. To change the output, you have to trace the chain back to the relevant instructions and change what they do with the input. This can make hunting down errors in the program or simply experimenting with different outputs an unintuitive process of jumping back-and-forth.
Artist and programmer Toby Schachman thinks we can do better. As part of his thesis project for the Interactive Telecommunications Program at New York University, he developed an experimental programming interface called Recursive Drawing, in which programmers can incrementally build up complex fractal-like structures. The design lets them manipulate the underlying source code by simply dragging parts of the patterns around. "When people describe algorithms they'll give a spatial analogy almost all the time," says Schachman. Though still in its early stages, the ideas behind the interface could change the way programming is done. Think of interacting with Photoshop.
"The form that you're working in resembles the thing that you're creating," says Schachman - there is no need to worry about changing the underlying code. His prototype works in much the same way. He will present it at the Splash programming conference in Tucson, Arizona, in October.
He's not alone in wanting to simplify the coding process. Bret Victor, who has designed user interfaces for Apple, is another developer who wants to open up programming to a wider community. "To write code you essentially have to play computer. You have to simulate in your head what each line of code would do," he said in a talk last year at the Canadian University Software Engineering Conference. "So much of creation is about discovery and you can't discover anything if you can't see what you're doing."
Schachman's approach is a good start, agrees Peter van Roy, a computer scientist at the Catholic University of Louvain (UCL) in Belgium and developer of FractaSketch, a graphical design tool based on fractals that has been used in the fashion industry. "Text-based programming is still the best way to give precise instructions to a computer," he says. But there's a big gap between writing the text and seeing what the running program does. "Bringing in graphical ideas like Schachman does can definitely reduce this gap," he adds
Sara Jones at City University in London, who is researching creative techniques for software development, says Recursive Drawing is part of a trend that will help to democratise programming. "It opens up the process of programming to a broader community of people, including artists, architects and designers, for whom the unnecessary translation of ideas into text may constitute a frustrating and unwelcome block to the flow of creative ideas," she says.
- It is currently Wed Nov 11, 2026 9:00 pm
Visual programming means anyone can be a coder
