Computer boot up problem
Posted: Thu Jun 16, 2011 1:37 am
I have problem with my PC. I will try to explain it as good as I can.
Suppose that I have left my computer off(not connected to mains) for about 8 hours, and then try to turn on after providing mains. And after turning on mains supply from UPS, when I press power button on computer the power LED turns on and then turns off instantly. Then for few seconds, computer does not turn on for few seconds (about 10 seconds) no matter how hard I press the power button. After about 10 seconds it turns on. I tried to check the power good signal with multimeter because i am worried that it might be just wired to the +5V lane without having proper monitoring circuits since my power supply is a cheap one.
But power good goes to +5V after pressing power button. I am thinking of buying a Cooler Master power supply. But I am not sure if this is a problem with the motherboard.
One of my friends had this kind of problem. We had to keep it in the sunlight to heat up in order it to boot (a loose joint for sure).
I am just writing because i want to know if there is anyone with similar experience.
I will try to check it again tomorrow with multimeter, but I have a question. Is it supposed for the power good signal to be 0V when the computer motherboard is off(provided that power to PSU is supplied, motherboard LED is lit up).
Another thing to mention is that I heard another capacitor explosion sound from the computer. But could not find any exploded capacitor on the motherboard,sound card or the PSU. And I am not quite sure if this problem started after that sound.
