IEEE 829 Compliant Test Plan Template
Posted: Fri Nov 27, 2009 2:40 am
by Saman
There are 16 clauses of the IEEE 829 test plan standard that are as follows:
  1. Test plan identifier
  2. Introduction
  3. Test items
  4. Features to be tested
  5. Features not to be tested
  6. Approach
  7. Item pass/fail criteria
  8. Suspension criteria and resumption requirements
  9. Test deliverables
  10. Testing tasks
  11. Environmental needs
  12. Responsibilities
  13. Staffing and training needs
  14. Schedule
  15. Risks and contingencies
  16. Approvals
These can be matched against the five characteristics of a basic plan, with a couple left over that form part of the plan document itself.
Scope
Scope clauses define what features will be tested. An aid to doing this is to prioritize them using a technique such as MoSCoW.
3. Test Items: The items of software, hardware, and combinations of these that will be tested.
4. Features to Be Tested: The parts of the software specification to be tested.
5. Features Not to Be Tested: The parts of the software specification to be excluded from testing.
Resource
Resource clauses give the overall view of the resources to deliver the tasks.
11. Environmental Needs: What is needed in the way of testing software, hardware, offices etc.
12. Responsibilities: Who has responsibility for delivering the various parts of the plan.
13. Staffing And Training Needs: The people and skills needed to deliver the plan.
Time
Time clauses specify what tasks are to be undertaken to meet the quality objectives, and when they will occur.
10. Testing Tasks: The tasks themselves, their dependencies, the elapsed time they will take, and the resource required.
14. Schedule: When the tasks will take place.
Often these two clauses refer to an appendix or another document that contains the detail.
Quality
Quality clauses define the standard required from the testing activities.
2. Introduction: A high level view of the testing standard required, including what type of testing it is.
6. Approach: The details of how the testing process will be followed.
7. Item Pass/Fail Criteria: Defines the pass and failure criteria for an item being tested.
9. Test Deliverables: Which test documents and other deliverables will be produced.
The associated article on test documentation gives details of the IEEE 829 documentation.
Risk
Risk clauses define in advance what could go wrong with a plan and the measures that will be taken to deal with these problems. An outline of risk management is in an associated article.
8. Suspension Criteria And Resumption Requirements: This is a particular risk clause to define under what circumstances testing would stop and restart.
15. Risks And Contingencies: This defines all other risk events, their likelihood, impact and counter measures to over come them.
Plan Clauses
These clauses are parts of the plan structure.
1. Test Plan Identifier: This is a unique name or code by which the plan can be identified in the project's documentation including its version.
16. Approvals: The signatures of the various stakeholders in the plan, to show they agree in advance with what it says.
Example Test plan:
testplan.pdf
(96.71 KiB) Downloaded 878 times
