Digital signal processing (DSP) is the study of signals in a digital representation and the processing methods of these signals. DSP and analog signal processing are sub fields of signal processing. DSP has at least three major sub fields:
- Audio Signal Processing
- Digital Image Processing
- Speech Processing
The algorithms required for DSP are sometimes performed using specialized computers, which make use of specialized microprocessors called digital signal processors (also abbreviated DSP). These process signals in real time and are generally purpose-designed ASICs.
DSP domains
In DSP, engineers usually study digital signals in one of the following domains: time domain (one-dimensional signals), spatial domain (multidimensional signals), frequency domain, auto-correlation domain, and wavelet domains. They choose the domain in which to process a signal by making an educated guess (or by trying different possibilities) as to which domain best represents the essential characteristics of the signal. A sequence of samples from a measuring device produces a time or spatial domain representation, whereas a discrete Fourier transform produces the frequency domain information, that is the frequency spectrum. Auto-correlation is defined as the cross-correlation of the signal with itself over varying intervals of time or space.
Signal sampling
With the increasing use of computers the usage and need of digital signal processing has increased. In order to use an analog signal on a computer it must be digitized with an analog to digital converter (ADC). Sampling is usually carried out in two stages, discretization and quantization. In the discretization stage, the space of signals is partitioned into equivalence classes and discretization is carried out by replacing the signal with representative signal of the corresponding equivalence class. In the quantization stage the representative signal values are approximated by values from a finite set.
In order to properly sample an analog signal the Nyquist-Shannon sampling theorem must be satisfied. In short, the sampling frequency must be greater than twice the bandwidth of the signal (provided it is filtered appropriately). A digital to analog converter (DAC) is used to convert the digital signal back to analog. The use of a digital computer is a key ingredient into digital control systems.
Time and space domains
The most common processing approach in the time or space domain is enhancement of the input signal through a method called filtering. Filtering generally consists of some transformation of a number of surrounding samples around the current sample of the input or output signal. There are various ways to characterize filters; for example:
- A "linear" filter is a linear transformation of input samples; other filters are "non-linear." Linear filters satisfy the superposition condition, i.e. if an input is a weighted linear combination of different signals, the output is an equally weighted linear combination of the corresponding output signals.
- A "causal" filter uses only previous samples of the input or output signals; while a "non-causal" filter uses future input samples. A non-causal filter can usually be changed into a causal filter by adding a delay to it.
- A "time-invariant" filter has constant properties over time; other filters such as adaptive filters change in time.
- Some filters are "stable", others are "unstable". A stable filter produces an output that converges to a constant value with time, or remains bounded within a finite interval. An unstable filter produces output which diverges.
- A "finite impulse response" (FIR) filter uses only the input signal, while an "infinite impulse response" filter (IIR) uses both the input signal and previous samples of the output signal. FIR filters are always stable, while IIR filters may be unstable.
Frequency domain
Signals are converted from time or space domain to the frequency domain usually through the Fourier transform. The Fourier transform converts the signal information to a magnitude and phase component of each frequency. Often the Fourier transform is converted to the power spectrum, which is the magnitude of each frequency component squared.
The most common purpose for analysis of signals in the frequency domain is analysis of signal properties. The engineer can study the spectrum to get information of which frequencies are present in the input signal and which are missing.
There are some commonly used frequency domain transformations. For example, the cepstrum converts a signal to the frequency domain through Fourier transform, takes the logarithm, then applies another Fourier transform. This emphasizes the frequency components with smaller magnitude while retaining the order of magnitudes of frequency components.
Applications
The main applications of DSP are audio signal processing, audio compression, digital image processing, video compression, speech processing, speech recognition and digital communications. Specific examples are speech compression and transmission in digital mobile phones, equalization of sound in Hifi equipment, weather forecasting, economic forecasting, seismic data processing, analysis and control of industrial processes, computer-generated animations in movies, medical imaging such as CAT scans and MRI, image manipulation, and audio effects for use with electric guitar amplifiers. A further application is very low frequency (VLF) reception with a PC sound card.
Techniques
- Bilinear transform
- Discrete Fourier transform
- Discrete-time Fourier transform
- Filter design
- LTI system theory
- Minimum phase
- Transfer function
- Z-transform
- Goertzel algorithm
