Dear Friends ,
I am a beginer to microcontrollers and I was able to wrote some program to blinking some LED's in some pattern.
I have a PIC 16F876 microcontroller. My question is how I enter my program in to the the PIC Microcontroller..
Thanks,
Lasitha
How to flash the program ...
Re: How to flash the program ...
if you write some programe and compile it with suitable compiler , a file which have the extention of .hex will
generate in the folder , which contain your project. you have to download this .hex file to the particular microcontroller , by
using some flash programmer.
There are lots of Circuits for PIC flash programmers , in the internet. you can easily make such a programmer , on your own.
PIC Programmers are available in both parallel port and serial port
" Do not live as you are never going to die , because then you will die as if you never lived "
