DDRB = 0xff;Code: Select all
PORTB = 0xff;Code: Select all
DDRB |= 1 << DDB2;Set port D pin 2 as input
DDRB &= ~(1 << DDB2);Set port B pin 2 to 1 (ON)
PORTB |= _BV(PB2);Code: Select all
PORTB |= 1 << 2;Code: Select all
PORTB |= 1 << PINB2;Set port B pin 2 to 0 (OFF)
PORTB &= ~_BV(PB2);Code: Select all
PORTB &= ~(1 << 2);Code: Select all
PORTB &= ~1 << PINB2;Code: Select all
if (PIND & (1<<PIND3))
}Check if port D pin 3 equal to 0 (OFF
if (!(PIND & (1<<PIND3)))
