Digital signal in FM frequency
Enigma
Post by Enigma » Wed Jul 20, 2011 6:00 am
Hi Guys
My elder sister's son is 5 yr old and he is pretty good at breaking things :D :D :D . So few dayz ago he got a new toy car and of course he broke it within one day. Its with me now and planing to turn that car in to a remotely controllable one. I know little about digital electronics. But my knowledge in analog electronics is ground zero :( . So I'm planing to use digital electronics for this. But the only issue is the transmitter and receiver. Is it possible to modulate a digital code in a FM carrier frequency ? If so can any give me an example or any information regarding this ?
If not what is best way to achieve this ?
Re: Digital signal in FM frequency
Post by Nipuna » Wed Jul 20, 2011 7:56 am
I don't know much friend.
But since you are lack of free time, How about buying a unit(Remote controller and Receiver) from eBay?
Post by Rksk » Wed Jul 20, 2011 9:11 pm
Hi,
it's a nice idea :)
1st, did u checked that how it works? can you put some pictures of it? we will can talk on it. anyway it seems this topic is not suitable :)
BTW, If you can build digital side of both of remote control & the toy, it's very easy to build
the transmitter & receiver for it.
you can find a small fm microphone & a fm reciever circuit from an electronic shop easily. also if you are interested in building ciruits you can try one like below one. but building a fm reciever is not a good idea.
http://sound.westhost.com/project54.htm
Shane
Post by Shane » Thu Jul 21, 2011 7:58 am
I found it is hard to make RF transceivers even with years of expereince. Even it is a kind of worthless when the working guaranteed modules are already available.
NRF24L01 Wireless Transceiver Module is one good example. You can buy two of them for < $8 and I'm sure it will cost you more to even build one. Have a look at this eBay deal. http://cgi.ebay.com/Arduino-NRF24L01-Wi ... 415b5fd1b8.
The coding would be very easy.
TX mode:
void setup()
	SPI_DIR = ( CE + SCK + CSN + MOSI);
	SPI_DIR &=~( IRQ + MISO);
	Serial.begin(9600);
	init_io();
	TX_Mode();
void loop()
	unsigned char status=0;
	unsigned char key=0;
	for(;;)
		tx_buf[1]=key;
		key++;
		status=SPI_Read(STATUS);
		if(status&TX_DS)
			SPI_RW_Reg(FLUSH_TX,0);
			Serial.println(tx_buf[1],HEX);
			SPI_Write_Buf(WR_TX_PLOAD,tx_buf,TX_PLOAD_WIDTH);
		SPI_RW_Reg(WRITE_REG+STATUS,status);
		delay(1000);
RX mode:
void setup()
	SPI_DIR&=~ ( IRQ + MISO);
	Serial.begin(9600);
	init_io();
	RX_Mode();
void loop()
	for(;;)
		tx_buf[1]=key;
		key++;
		if(status&TX_DS)
		SPI_RW_Reg(WRITE_REG+STATUS,status);// clear RX_DR or TX_DS or MAX_RT interrupt flag
		delay(1000);
You can find a sample TX, RX code here:
nRF24L01_Demo_For_Arduino.zip
(7.61 KiB) Downloaded 1489 times
If you really want to build it yourself, you can find the schematic in the following archive.
NRF24L01_module.zip
(1.18 MiB) Downloaded 965 times
More information can be found in Arduino site.
Post by Saman » Thu Jul 21, 2011 8:44 am
I agree with Shane. I have another idea. How if you buy a R/C toy (car, boat, etc...) for about LKR 500 (US$ 5) and modify the circuit for your need?
Post by Rksk » Thu Jul 21, 2011 6:44 pm
Saman wrote:I agree with Shane. I have another idea. How if you buy a R/C toy (car, boat, etc...) for about LKR 500 (US$ 5) and modify the circuit for your need?
:lol: there is no anything to do, just play with new toy :)
I have suggested to buy a small fm microphone (LKR100) and a FM reciver circuit (LKR200). You can tune them and use with a areal.
Post by Saman » Thu Jul 21, 2011 8:34 pm
Guess it will make things complicated. It would require a DAC and a ADC on both sides (if two way communication is required) which will increase the cost. All-in-one ICs are common these days. These ICs have both DAC and ADC built-in in addition to the transceiver. I guess Rksk is clear on the point now. Even if we establish a radio link, there should be a way to send signals from one end to the other. This is where we need to spend some more money on doing DAC and then ADC. If it is me, I would get this approach since making things is more fun than buying things for an engineer.
I have found one for even less ($2.99 per side) at http://cgi.ebay.com/RF-2400W-2-4GHz-Wir ... 0706930116.
What you are saying has a point. Why not we play with this one ;)
One point is this. The R/C cars available for LKR 500 are very cheap. No need to say this. Steering is so bad on these. So if Enigma has a better car, it is worth to get the things moved carefully. The main point is not that. If Enigma takes the first approach, he would learn quite a lot of things by playing with uCs, etc... while having quite a lot of fun.
Buying a R/C car for LKR 500 will be cost effective for this project.
Enigma
Post by Enigma » Thu Jul 21, 2011 11:05 pm
wow this is great guyzz. Now I have options. Thank you all. :)
SemiconductorCat
Post by SemiconductorCat » Tue Aug 23, 2011 8:54 pm
this is a circuit that I also looked for a long time. thanks.
There are modules to do it but those modules/chips are not available in the SL markert.
