"working wth tht cmos camera is more difficult thn it seems. refer the link below, most microcontrollers are unable to interface with such big data." and he'd Included a link from another forum (i didnt include that link or specify the name of the page because im not thorough with the rules and terms of use in robot.lk )
(this person is asking about the i2C cam ...As I see it your basic problem is finding a device with enough memory to hold a single image. Do you know how to calculate that number? NO -- well here's an example. A standard VGA image with 640 x 480 pixels times 8 bits for each pixel is -- ta da -- 307,200 bytes. That number eliminates most of the microcontrollers that I know about.
from this and from what my adviser says, this 12C cam can't be easily applied :/ ..
http://www.ebay.com/itm/3-5-New-TFT-LCD ... 7145wt_952
this is a normal rear cam+display ,im not very sure about the cam's video feed achieving distance...Im going to need a cam that'd clearly detect objects within a 10m parameter ,and this display is very thick it seems , so it might be problematic when fixing that to the helmet shield, because! to what I've tried and experimented there should be at least 10cm distance from the naked eye to view a Display's video feed clearly without blurry vision
and finally if i choose these cams & displays , can you estimate how long the battery will hold in these different scenarios
a) 3-5inch LCD display + i2C cam + the IR illuminator that I've given earlier
b) this rear car cam set+ IR illuminator
c) what ever other cam that you suggest + 3-5inch LCD + IR illuminator ?????????
hi,
This is soo possible using a normal web cam.I'm telling this because one of
my friend built that.
web cams are come with a IR filter. Where you can easily do that conversion but
not easy in some cams, because in some chips the filter is placed inside the CCD
chip or more closer to it.
I'll already mailed my friend , hopefully I'm waiting for a answer now.
yeah sadun , as he said we've discussed about that implication earlier ..... for this project however that wont be enough since im trying to light down the weight as much as i canSandun,
Rasanja is going to build something for an exhibition. He needs to fix a cam with IR illumination and get the output to a little LCD fixed on the helmet. Everything is battery powered so a person can wear it. Rasanja is almost in to the final steps of planning his project and he needs to discuss with his electronic designer on the microcontroller they are going to use, etc....
Since it seems you haven't read the topic form the beginning, it is recommended for anyone who thinks to jump in to read from the beginning. Otherwise it can be disturbing for all the participants. It is not required to answer all the posts. Please answer only if you know (no need to ask from friends and submit here since we have professionally qualified members in every engineering discipline we discuss here.. just ask your friends to join with us).
We need to keep ROBOT.LK with highest possible quality.
I hope you'll understand
