AT28C64B , 93C46B , AT89C2051-24PI , AT27C040 [SMD type], AT28C64E [SMD type]
& AM29F010
match ??? programmer1 ????????? ??????? ???????? ????? ???? idea 1?? ?????.
thanx
Are you referring ISP mode? Some JTAGs such as Atmel JTAGICE MKii supports both JTAG, ISP and DebugWire. In some cases of Atmel, to enable DebugWire, it is required to connect SPI pins to the JTAG module to fuse but I don't think you mention that. When you buy a JTAG, you will have to read carefully on the specification on supporting devices and interfaces.can't use any JTAG interface in general in it's SPI mode?
