?? ??? Pic programming ????? . ??? ?? ?????? ??????? ??? serial port ?? ??? ????? ???? . ???? ???? ??? ic porg ?? install ???? try ??? programme ?????? ?? .
thank you
How to chek serial port working or not?
Chamith119
- Sergeant Major
- SemiconductorCat
- Major
Re: How to chek serial port working or not?
Do you have a analog multimeter? ( As I always told you analog multimeter is your swis army knife).
Then you could install realterm software http://realterm.sourceforge.net/
and toggle RTS DTR status and put the multimeter on pin 7 and pin 4 and simply check whether
the output is changing according to your toggling.
Even you could change those status using a simple C++ program: https://sites.google.com/site/sandundha ... serialport [This may sometimes useful].
Anyway sounds like you have DIY made your programmer. Even you could use the old JDM programmer with
usb2serial adapter,it's not recommended. Simply you could order a RHoS PICKIT2 from TRONIC.LK,
But you have to understand one thing, what's going inside a programmer is not magic, and even it's not complicated.
I think PICKIT2 is a open-source design already. So feel free to use it. But nothing like your own home-made PIC programmer could program your chip in the newbie level right?
????? PC ??? ????? serial port ????? use ??????? ?????? ??????? USB to Serial converter ?????? ?? ??????? ??? use ?????? JDM programmer ???? ????? ??. ??? PC ??? ????? built-in serial port ???. ??? ????? ???? microcontrollers ??? program ????? 13V ???. ???? serial port ?? check ?????? ????? ????? ????? ???? serial port ??? pin 2 ?? pin 3 ??? short ????, ?? semi ???? ????? Realterm ??? software ???? use ???? transmit ??? data, loopback ???? ??? ??. ?????? ?????????? ?????. ????? pin short ?????? port ?? ????????? ???????
Chamith119
- Sergeant Major
thanx brother
??? check ???? ????????
SukhdeepMankoo
- Lieutenant
Short pin 2 & 3 of serial port(DB 9 connector). Open hyper terminal for same serial port number like COM1 and type any character. You will see same character two times in screen. It means serial port is working.
Chamith119
- Sergeant Major
realterm eka use karal serial port eka chek karganne kohomada ? software eka use karn hati danne nane .
