Fix: Virtualmin can't set Local server scanner for ClamAV with Cent OS 7
Linux OS Topics
Post by Saman » Thu Nov 22, 2018 8:36 am
If you finding difficulties setting Local server scanner mode for Virtualmin for ClamAV, here is what you need to do.
touch /var/run/clamd.scan/clamd.sock
chown clamscan: /var/run/clamd.scan/clamd.sock
Uncommented these lines in /etc/clamd.d/scan.conf:
PidFile /var/run/clamd.scan/clamd.pid
LocalSocket /var/run/clamd.scan/clamd.sock
Finally restart both Postfix and ClamAV
systemctl restart postfix
systemctl restart clamd@scan.service
Return to “Linux”
