Follow the procedure below to install software packaged in a .run file:
- Find the .run file in the File Browser
- Right-click the file and select Properties
- Under the Permissions tab, make sure that Allow executing file as program is ticked and press Close
- Double-click the .run file to open it. A dialog box should appear
- Press Run in Terminal to run the installer
- A Terminal window will open. Follow any instructions on-screen to install the program
