yum updateCode: Select all
yum search any-packageCode: Select all
yum search httpdConsultation of information. To consult the information contained in a package in individual:
yum info any-packageCode: Select all
yum info httpdCode: Select all
yum install any-packageCode: Select all
yum install gkrellmCode: Select all
yum remove any-packageCode: Select all
yum remove gkrellmCode: Select all
available yum list|lessCode: Select all
yum list installed|lessCode: Select all
yum list updates|lessYum leaves as result of its use heads and packages RPM stored in the interior of the directory located in the route /var/cache/yum/. Particularly the packages RPM that have settled can occupy much space and is by such reason agrees to eliminate them once no longer they have utility. Also it agrees to do the same with the old heads of packages that no longer are in the data base. In order to make the corresponding cleaning, the following thing can be executed:
yum clean allCode: Select all
yum groupinstall "groupname"To install a set of application that starts with a common prefix. To install gkrellm, gkrellm-plugins, gkrellm-misc-plugins,
yum install gkrellm*Code: Select all
yum list somethingCode: Select all
yum list mozillaCode: Select all
yum provides filenameCode: Select all
yum provides /usr/bin/mozillaTo get a list of packages updated/added to any of your repositories recently:
yum list recentCode: Select all
yum --enablerepo=reponame install packagenameCode: Select all
yum --enablerepo=dag install j2reCode: Select all
yum grouplistCode: Select all
yum groupinstall "groupname"Code: Select all
yum groupinstall "GNOME Desktop Environment"Code: Select all
yum groupupdate "GNOME Desktop Environment"
