You can change the owner and group of a file or a directory with the chown command. Please, keep in mind you can do this only if you are the root user or the owner of the file.
Set the file's owner:
$ chown username somefileYou can also set the file's group at the same time. If the user name is followed by a colon and a group name, the file's group will be changed as well.
$ chown username:usergroup somefileYou can set the owner of a directory exactly the same way you set the owner of a file:
$ chown username somedirIn order to set the ownership of a directory and all the files in that directory, you'll need the -R option:
$ chown -R username somedirTell what happens:
$ chown -v username somefileHere, v stands for verbose. If you use the -v option, chown will list what it did (or didn't do) to the file.
The verbose mode is especially useful if you change the ownership of several files at once. For example, this could happen when you do it recursively:
$ chown -Rv username somedirchanged ownership of 'somedir/boringfile' to username
changed ownership of 'somedir/somefile' to username
As you can see, chown nicely reports to you what it did to each file.
chgrp - change the group ownership of a file
In addition to chown, you can also use the chgrp command to change the group of a file or a directory. You must, again, be either the root user or the owner of the file in order to change the group ownership.
chgrp works pretty much the same way as chown does, except it changes the file's user group instead of the owner, of course.
$ chgrp usergroup somefileThe options of using chgrp are the same as using chown. So, for example, the -R and -v options will work with it just like they worked with chown:
$ chgrp -Rv usergroup somedirchanged group of 'somedir/boringfile' to usergroup
changed group of 'somedir/somefile' to usergroup
