It’s much better to have a separate account that you regularly use and simply sudo to root when necessary. Before we begin, you should make sure that you have a regular user account and that you can su or sudo to root from it.
To fix this problem, we’ll need to edit the sshd_config file, which is the main configuration file for the sshd service. The location will sometimes be different, but it’s usually in /etc/ssh/. Open the file up while logged on as root.
vi /etc/ssh/sshd_configCode: Select all
#LoginGraceTime 2m
#PermitRootLogin no
#StrictModes yes
#MaxAuthTries 6Code: Select all
PermitRootLogin noCode: Select all
/etc/init.d/sshd restart
