Any changes made to the original or Hard linked file will reflect the other.
Even if you delete any one of the files, nothing will happen to the other.
Hard links can't cross file systems.
Soft Link is a symbolic link to the original file. Soft Links will have a different Inode value.
A soft link points to the original file. If you delete the original file, the soft link fails. If you delete the soft link, nothing will happen.
Hard links can cross file systems.
Lets learn the difference with an example
Example: Create a file " original-file.txt "
:~/test$ echo "Learning about Hard and Soft Link" > original-file.txt
:~/test$ cat original-file.txt
Learning about Hard and Soft LinkExample: HardLink-file.txt
:~/test$ ln original-file.txt HardLink-file.txt
:~/test$ ls -il
total 8
840388 -rw-r--r-- 2 telson telson 33 2009-05-18 09:16 HardLink-file.txt
840388 -rw-r--r-- 2 telson telson 33 2009-05-18 09:16 original-file.txtNow lets create a Soft Link
Example: SoftLink-file.txt
:~/test$ ln -s original-file.txt SoftLink-file.txt
:~/test$ ls -il
total 8
840186 lrwxrwxrwx 1 telson telson 17 2009-05-18 09:23 SoftLink-file.txt -> original-file.txtInode value is different for the soft link " SoftLink-file.txt ".
Now lets try editing the original file:
Example:
:~/test$ cat >> original-file.txt
Editing this file to learn more!!
:~/test$ cat HardLink-file.txt
:~/test$ cat SoftLink-file.txt
Example:
:~/test$ chmod 700 original-file.txt
:~/test$ ls -il
total 8
840388 -rwx------ 2 telson telson 67 2009-05-18 09:34 HardLink-file.txt
840388 -rwx------ 2 telson telson 67 2009-05-18 09:34 original-file.txt
840186 lrwxrwxrwx 1 telson telson 17 2009-05-18 09:23 SoftLink-file.txt -> original-file.txtThe soft link remains unchanged.
Now lets try deleting the original file.
Example:
:~/test$ rm original-file.txt
:~/test$ ls -il
total 4
840388 -rwx------ 1 telson telson 67 2009-05-18 09:34 HardLink-file.txt
cat: SoftLink-file.txt: No such file or directoryHard link is unaffected.
