tcp 0 0 app.example.com:http 93.184.216.119:16494 SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119:18733 SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119.dsl.mwe:64775 SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119.threembb.:16490 SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119:video-activmail SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119:45025 SYN_RECV
tcp 0 0 app.example.com:http 93.184.216.119:dvl-activemail SYN_RECV
tcp 0 0 app.example.com:http 41-135-22-100.dsl.mwe:64774 SYN_RECVCode: Select all
netstat -an | wc -lCode: Select all
netstat -an | grep :80 | wc -lCode: Select all
netstat -ant | awk '{print $6}' | sort | uniq -c | sort -n
1 CLOSING
1 established
1 FIN_WAIT2
1 Foreign
2 CLOSE_WAIT
6 FIN_WAIT1
7 LAST_ACK
7 SYN_RECV
37 ESTABLISHED
44 LISTEN
297 TIME_WAITCode: Select all
[root@server ~]# netstat -l
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 0 electrolanka.com:rfio 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:submission 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:pop3 0.0.0.0:* LISTEN
tcp 0 0 localhost:783 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:imap 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:sunrpc 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:ndmp 0.0.0.0:* LISTEN
tcp 0 0 0.0.0.0:urd 0.0.0.0:* LISTENCode: Select all
[root@server ~]# netstat -s
Ip:
127126899 total packets received
0 forwarded
9 with unknown protocol
0 incoming packets discarded
126998074 incoming packets delivered
105806208 requests sent out
27 outgoing packets dropped
48 dropped because of missing route
6272 fragments dropped after timeout
6273 reassemblies required
6272 packet reassembles failed
Icmp:
342522 ICMP messages received
35995 input ICMP message failed.
InCsumErrors: 3
ICMP input histogram:
destination unreachable: 56408
timeout in transit: 855
redirects: 15
echo requests: 285138
echo replies: 96
timestamp request: 7
432921 ICMP messages sent
0 ICMP messages failed
ICMP output histogram:
destination unreachable: 141594
time exceeded: 6182
echo replies: 285138
timestamp replies: 7
IcmpMsg:
InType0: 96
InType3: 56408
InType5: 15
InType8: 285138
InType11: 855
InType13: 7
OutType0: 285138
OutType3: 141594
OutType11: 6182
OutType14: 7
Tcp:
620992 active connections openings
3099807 passive connection openings
87361 failed connection attempts
332654 connection resets received
12 connections established
89909519 segments received
136159669 segments send out
1312097 segments retransmited
977 bad segments received.
985970 resets sent
InCsumErrors: 730
Udp:
39076419 packets received
42846 packets to unknown port received.
268 packet receive errors
39084296 packets sent
0 receive buffer errors
0 send buffer errors
InCsumErrors: 268
UdpLite:
TcpExt:
53007 invalid SYN cookies received
19201 resets received for embryonic SYN_RECV sockets
3 ICMP packets dropped because they were out-of-window
1903393 TCP sockets finished time wait in fast timer
4809 packets rejects in established connections because of timestamp
675451 delayed acks sent
1278 delayed acks further delayed because of locked socket
Quick ack mode was activated 79053 times
980 times the listen queue of a socket overflowed
1430 SYNs to LISTEN sockets dropped
2501421 packets directly queued to recvmsg prequeue.
68476567 bytes directly in process context from backlog
3269301520 bytes directly received in process context from prequeue
7547099 packet headers predicted
1926072 packets header predicted and directly queued to user
32847883 acknowledgments not containing data payload received
28768928 predicted acknowledgments
857 times recovered from packet loss due to fast retransmit
193137 times recovered from packet loss by selective acknowledgements
246 bad SACK blocks received
Detected reordering 1406 times using FACK
Detected reordering 1949 times using SACK
Detected reordering 21 times using reno fast retransmit
Detected reordering 6541 times using time stamp
3031 congestion windows fully recovered without slow start
5952 congestion windows partially recovered using Hoe heuristic
4338 congestion windows recovered without slow start by DSACK
30785 congestion windows recovered without slow start after partial ack
TCPLostRetransmit: 24261
154 timeouts after reno fast retransmit
21210 timeouts after SACK recovery
11008 timeouts in loss state
472830 fast retransmits
43723 forward retransmits
87853 retransmits in slow start
1695353 other TCP timeouts
TCPLossProbes: 129123
TCPLossProbeRecovery: 28947
299 classic Reno fast retransmits failed
27728 SACK retransmits failed
20 times receiver scheduled too late for direct processing
91329 DSACKs sent for old packets
540 DSACKs sent for out of order packets
91082 DSACKs received
1802 DSACKs for out of order packets received
244676 connections reset due to unexpected data
18433 connections reset due to early user close
26405 connections aborted due to timeout
TCPSACKDiscard: 822
TCPDSACKIgnoredOld: 822
TCPDSACKIgnoredNoUndo: 41086
TCPSpuriousRTOs: 25509
TCPSackShifted: 436117
TCPSackMerged: 864297
TCPSackShiftFallback: 610372
TCPDeferAcceptDrop: 2821626
TCPRetransFail: 30
TCPRcvCoalesce: 1705875
TCPOFOQueue: 470742
TCPOFOMerge: 365
TCPChallengeACK: 10950
TCPSYNChallenge: 268
TCPFastOpenCookieReqd: 35
TCPSpuriousRtxHostQueues: 10
TCPAutoCorking: 7949083
TCPFromZeroWindowAdv: 113
TCPToZeroWindowAdv: 113
TCPWantZeroWindowAdv: 341
TCPSynRetrans: 284969
TCPOrigDataSent: 118567808
TCPHystartTrainDetect: 5381
TCPHystartTrainCwnd: 1742831
TCPHystartDelayDetect: 12737
TCPHystartDelayCwnd: 744627
TCPACKSkippedSynRecv: 1559
TCPACKSkippedPAWS: 2541
TCPACKSkippedSeq: 2241
TCPACKSkippedTimeWait: 166
TCPACKSkippedChallenge: 441
IpExt:
InNoRoutes: 2
InMcastPkts: 47
OutMcastPkts: 49
InOctets: 29122264496
OutOctets: 165757922236
InMcastOctets: 7129
OutMcastOctets: 7209
InNoECTPkts: 129867090
InECT1Pkts: 316
InECT0Pkts: 455518
InCEPkts: 3900
[root@server ~]# netstat -p
Active Internet connections (w/o servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 ns3.example.c:http vmi150956.contabo:48464 SYN_RECV -
tcp 0 0 ns4.example.c:http 45.xx.168.xx:364z2 SYN_RECV -
tcp 0 0 ns3.example.:imaps xx.165.153.xx:3z496 ESTABLISHED 2xcv8/dovecot/imap-
tcp 0 272 example.com:rfio 123.2xx.10x.xx2:2zz40 ESTABLISHED 2zz7/sshd: root@pts
