DCP 650VA UPS circuit
Re: DCP 650VA UPS circuit
My Father Repaired the UPS. He said me He disconnected a one pin of LM 339N IC from the circuit. now it's working well. I use my UPS like this until we find the IC.
Thanks for your help. If i want more help i will ask you.
Thanks again.
Thanks again.
friend,
can you give us a clear idea about , what did your father?'
THANKZ
THANKZ
He removed one Pin Of LM 335N Ic from the circuit board.
Is there any way to Repair UPS Battery?
You might be already knowing that the LM339 is a quad voltage comparator.One time I connected a 12V Bulb and it lighted well 5 Minutes. After that i Disconnected the bulb. I couldn't check it because it started to rain and Lightning. I have Replaced the LM 339N IC. Now it's working well but when i connect My Computer to the UPS After Disconnecting AC current then UPS sounds a Long Beep and then Lights Red and Yellow LEDs then Turns off. But when i connect the Monitor it's working well. I tried to Charge the battery for a whole Night But it isn't charging. I Disconnected the battery from the UPS's Circuit and Charged it with a Power pack that i Found in Our shop it's a power pack that we made. Not a Bought one. It's Transformer is 16V and 2 AMP. But I checked the Power Pack But it has 22V. I charged the Battery after that I connected it back to the UPS. But same as before can't Power on the Computer. But one time It charged a Bit from the UPS's circuit then gave the power to the Computer for a half second.
What this Might be?
This is used for many applications including Voltage Window Detection, Voltage Level Detection, Power-On Delay Timers, etc... Try to trace the circuit to see where the IC is connected.
My idea is still you need to replace the battery. Since those are sealed led-acid batteries, there is a fewer chance to repair them.
Thanks Neo,
I will Check the Circuit board and replace LM339 again. Then I will Replace the Battery.
Today I Disconnected the battery from the circuit board then. I checked the wires that Give power to charge the Battery. The voltage was 8.5V. Now I am Charging Battery using an External Power pack That i Told you earlier. Now battery Is Charging.
What could be this Problem.
I think you right Neo.
after replacing LM339N the self turning off problem that i told earlier solved. But I have to replace the battery.
Help Friends,
I have replaced my UPS's Battery. Now there is another problem, That is
After replacing that Battery I was charging my UPS for 24 hours because I thought
It might be good for my New Battery. When i was charging the Battery lights went off.
Then UPS began to Beep. Then After a half minute UPS turned off by itself. I didn't
Connect any power code that comes from Monitor and system unit. What could this be?
Please Help.
Please Help.
Have you placed the components intact after replacing the battery. I remember you were experimenting with a comparator IC?
What are the ratings of the battery that you have replaced? (is it a 12V, 7Ahrs?)
What happens if you power on the UPS now? Any beeps, indicators?
