MPLEX DVD/VCD Multiplexer Command Line Arguments
Posted: Wed Jan 13, 2010 1:59 pm
mjpegtools mplex-2 version 2.0.0 (2.2.3)
Usage: D:\RT_TDM\RT\Prj 34 FFMPEG\demux\mplex.exe [params] -o <output filename pattern> <input file>...
         %d in the output file name is by segment count where possible params are:
--verbose|-v num
  Level of verbosity. 0 = quiet, 1 = normal 2 = verbose/debug
--format|-f fmt
  Set defaults for particular MPEG profiles
  [0 = Generic MPEG1, 1 = VCD, 2 = user-rate VCD, 3 = Generic MPEG2,
   4 = SVCD, 5 = user-rate SVCD
   6 = VCD Stills, 7 = SVCD Stills, 8 = DVD with NAV sectors, 9 = DVD]
--mux-bitrate|-r num
  Specify data rate of output stream in kbit/sec
    (default 0=Compute from source streams)
--video-buffer|-b num [, num...]
  Specifies decoder buffers size in kB.  [ 20...2000]
--lpcm-params | -L samppersec:chan:bits [, samppersec:chan:bits]
--mux-limit|-l num
  Multiplex only num seconds of material (default 0=multiplex all)
--sync-offset|-O num ms|s|mpt
  Specify offset of timestamps (video-audio) in mSec
--sector-size|-s num
  Specify sector size in bytes for generic formats [256..16384]
--vbr|-V
  Multiplex variable bit-rate video
--packets-per-pack|-p num
  Number of packets per pack generic formats [1..100]
--system-headers|-h
  Create System header in every pack in generic formats
--max-segment-size|-S size
  Maximum size of output file(s) in Mbyte (default: 0) (no limit)
--split-segment|-M
  Simply split a sequence across files rather than building run-out/run-in
--workaround|-W workaround [, workaround ]
--help|-?
  Print this lot out!
Download this version of mplex.exe
mplex.zip
(30.38 KiB) Downloaded 675 times
