jParallax turns a selected element into a ‘window’, or viewport, and all its children into absolutely positioned layers that can be seen through the viewport. These layers move in response to the mouse, and, depending on their dimensions (and options for layer initialisation), they move by different amounts, in a parallaxy kind of way.
Linking javascripts
<script src="js/jquery-1.3.2.js" type="text/javascript"><!--mce:0--></script>
<script src="js/jquery.lightbox-0.5.min.js" type="text/javascript"><!--mce:1--></script>
<script src="js/jquery.jparallax.js" type="text/javascript"><!--mce:2--></script>Setup the window, give its id name parallax and width, so only this area responses to mouse movements. As the diagram shows above, the image you list first goes to the back.
Make sure the width is set properly to prevent collapsing view point. If any of the layer travels outside the parallax window, it will be hidden.
<div id="parallax"> <img style="width: 400px;" src="images/0.png" alt="" />
<img style="width: 500px;" src="images/1.png" alt="" />
<img style="width: 600px;" src="images/2.png" alt="" />
<img style="width: 550px;" src="images/3.png" alt="" /></div> Code: Select all
#parallax
{position:relative; overflow:hidden; width:800px; height:450px;border:none;
margin:0 auto 20px auto;}Code: Select all
jQuery(document).ready(function(){
jQuery('#parallax').();
}); jQuery(‘element’).jparallax(options, layer_0_options, layer_1_options, etc.);
jQuery('#parallax').jparallax({yparallax:false},{xtravel: '100px'},{xtravel: '300px'});
