How to force HTTPS (SSL) using .htaccess
Posted: Thu Nov 11, 2010 6:00 pm
Sometimes you may need to make sure that the user is browsing your site over secure connection. An easy to way to always redirect the user to secure connection (https://) can be accomplished with a .htaccess file containing the following lines:
Please, note that the .htaccess should be located in the web site main folder.
In case you wish to force HTTPS for a particular folder you can use:
The .htaccess file should be placed in the folder where you need to force HTTPS.
RewriteEngine On
RewriteCond %{SERVER_PORT} 80
RewriteRule ^(.*)$ https://www.example.com/$1 [R,L]In case you wish to force HTTPS for a particular folder you can use:
RewriteEngine On
RewriteCond %{REQUEST_URI} somefolder
RewriteRule ^(.*)$ https://www.domain.com/somefolder/$1 [R,L]
