What is socket communication
Network topics
Post by Saman » Wed Oct 13, 2010 5:26 pm
In computer networking, an network socket (Internet socket) is an endpoint of a bidirectional inter-process communication flow across an Internet Protocol-based computer network, such as the Internet.
The term network sockets is also used as a name for an application programming interface (API) for the TCP/IP protocol stack, usually provided by the operating system. Network sockets constitute a mechanism for delivering incoming data packets to the appropriate application process or thread, based on a combination of local and remote IP addresses and port numbers. Each socket is mapped by the operating system to a communicating application process or thread.
A socket address is the combination of an IP address (the location of the computer) and a port (which is mapped to the application program process) into a single identity, much like one end of a telephone connection is the combination of a phone number and a particular extension.
An network socket is characterized by a unique combination of the following:
  • Local socket address: Local IP address and port number
  • Remote socket address: Only for established TCP sockets. As discussed in the Client-Server section below, this is necessary since a TCP server may serve several clients concurrently. The server creates one socket for each client, and these sockets share the same local socket address.
  • Protocol: A transport protocol (e.g., TCP, UDP), raw IP, or others. TCP port 53 and UDP port 53 are consequently different, distinct sockets.
Within the operating system and the application that created a socket, the socket is referred to by a unique integer number called socket identifier or socket number. The operating system forwards the payload of incoming IP packets to the corresponding application by extracting the socket address information from the IP and transport protocol headers and stripping the headers from the application data.
Socket types
  • Datagram sockets, also known as connectionless sockets, which use User Datagram Protocol (UDP)
  • Stream sockets, also known as connection-oriented sockets, which use Transmission Control Protocol (TCP) or Stream Control Transmission Protocol (SCTP).
  • Raw sockets (or Raw IP sockets), typically available in routers and other network equipment. Here the transport layer is bypassed, and the packet headers are not stripped off, but are accessible to the application. Application examples are Internet Control Message Protocol (ICMP, best known for the Ping suboperation), Internet Group Management Protocol (IGMP), and Open Shortest Path First (OSPF).
Socket states and the client-server model
Computer processes that provide application services are called servers, and create sockets on start up that are in listening state. These sockets are waiting for initiatives from client programs. For a listening TCP socket, the remote address presented by netstat may be denoted 0.0.0.0 and the remote port number 0.
A TCP server may serve several clients concurrently, by creating a child process for each client and establishing a TCP connection between the child process and the client. Unique dedicated sockets are created for each connection. These are in established state, when a socket-to-socket virtual connection or virtual circuit (VC), also known as a TCP session, is established with the remote socket, providing a duplex byte stream.
Other possible TCP socket states presented by the netstat command are Syn-sent, Syn-Recv, Fin-wait1, Fin-wait2, Time-wait, Close-wait and Closed which relate to various start up and shutdown steps.
A server may create several concurrently established TCP sockets with the same local port number and local IP address, each mapped to its own server-child process, serving its own client process. They are treated as different sockets by the operating system, since the remote socket address (the client IP address and/or port number) are different; i.e. since they have different socket pair tuples (see below).
A UDP socket cannot be in an established state, since UDP is connectionless. Therefore, netstat does not show the state of a UDP socket. A UDP server does not create new child processes for every concurrently served client, but the same process handles incoming data packets from all remote clients sequentially through the same socket. This implies that UDP sockets are not identified by the remote address, but only by the local address, although each message has an associated remote address.
Socket pairs
Communicating local and remote sockets are called socket pairs. Each socket pair is described by a unique 4-tuple struct consisting of source and destination IP addresses and port numbers, i.e. of local and remote socket addresses. As seen in the discussion above, in the TCP case, each unique socket pair 4-tuple is assigned a socket number, while in the UDP case, each unique local socket address is assigned a socket number.
Implementation
Development of application programs that utilize this API is called socket programming or network programming.
These are examples of functions or methods typically provided by the API library:
  • socket() creates a new socket of a certain socket type, identified by an integer number, and allocates system resources to it.
  • bind() is typically used on the server side, and associates a socket with a socket address structure, i.e. a specified local port number and IP address.
  • listen() is used on the server side, and causes a bound TCP socket to enter listening state.
  • connect() is used on the client side, and assigns a free local port number to a socket. In case of a TCP socket, it causes an attempt to establish a new TCP connection.
  • accept() is used on the server side. It accepts a received incoming attempt to create a new TCP connection from the remote client, and creates a new socket associated with the socket address pair of this connection.
  • send() and recv(), or write() and read(), or recvfrom() and sendto(), are used for sending and receiving data to/from a remote socket.
  • close() causes the system to release resources allocated to a socket. In case of TCP, the connection is terminated.
    gethostbyname() and gethostbyaddr() are used to resolve host names and addresses.
  • select() is used to prune a provided list of sockets for those that are ready to read, ready to write or have errors
  • poll() is used to check on the state of a socket. The socket can be tested to see if it can be written to, read from or has errors.
Following is a TCP socket communication flow diagram.
Return to “Computer Networks”
