How to configure Cisco router
Network topics
Cyclops
Post by Cyclops » Fri Oct 23, 2009 12:31 pm
Cisco Router Configuration
Cisco IOS Modes of Operation
The Cisco IOS software provides access to several different command modes. Each command mode provides a different group of related commands.
For security purposes, the Cisco IOS software provides two levels of access to commands: user and privileged. The unprivileged user mode is called user EXROBOT.LK mode. The privileged mode is called privileged EXROBOT.LK mode and requires a password. The commands available in user EXROBOT.LK mode are a subset of the commands available in privileged EXROBOT.LK mode.
The following table describes some of the most commonly used modes, how to enter the modes, and the resulting prompts. The prompt helps you identify which mode you are in and, therefore, which commands are available to you
User EXROBOT.LK Mode:
When you are connected to the router, you are started in user EXROBOT.LK mode. The user EXROBOT.LK commands are a subset of the privileged EXROBOT.LK commands.
Privileged EXROBOT.LK Mode:
Privileged commands include the following:
• Configure – Changes the software configuration.
• Debug – Display process and hardware event messages.
• Setup – Enter configuration information at the prompts.
Enter the command disable to exit from the privileged EXROBOT.LK mode and return to user EXROBOT.LK mode.
Configuration Mode
Configuration mode has a set of submodes that you use for modifying interface settings, routing protocol settings, line settings, and so forth. Use caution with configuration mode because all changes you enter take effect immediately.
To enter configuration mode, enter the command configure terminal and exit by pressing Ctrl-Z.
Note:
Almost every configuration command also has a no form. In general, use the no form to disable a feature or function. Use the command without the keyword no to re-enable a disabled feature or to enable a feature that is disabled by default. For example, IP routing is enabled by default. To disable IP routing, enter the no ip routing command and enter ip routing to re-enable it.
Getting Help
In any command mode, you can get a list of available commands by entering a question mark (?).
Router>?
To obtain a list of commands that begin with a particular character sequence, type in those characters followed immediately by the question mark (?).
Router#co?
configure connect copy
To list keywords or arguments, enter a question mark in place of a keyword or argument. Include a space before the question mark.
Router#configure ?
memory Configure from NV memory
network Configure from a TFTP network host
terminal Configure from the terminal
You can also abbreviate commands and keywords by entering just enough characters to make the command unique from other commands. For example, you can abbreviate the show command to sh.
Configuration Files
Any time you make changes to the router configuration, you must save the changes to memory because if you do not they will be lost if there is a system reload or power outage. There are two types of configuration files: the running (current operating) configuration and the startup configuration.
Use the following privileged mode commands to work with configuration files.
• configure terminal – modify the running configuration manually from the terminal.
• show running-config – display the running configuration.
• show startup-config – display the startup configuration.
• copy running-config startup-config – copy the running configuration to the startup configuration.
• copy startup-config running-config – copy the startup configuration to the running configuration.
• erase startup-config – erase the startup-configuration in NVRAM.
• copy tftp running-config – load a configuration file stored on a Trivial File Transfer Protocol (TFTP) server into the running configuration.
• copy running-config tftp – store the running configuration on a TFTP server.
IP Address Configuration
Take the following steps to configure the IP address of an interface.
Step 1: Enter privileged EXROBOT.LK mode:
Router>enable password
Step 2: Enter the configure terminal command to enter global configuration mode.
Router#config terminal
Step 3: Enter the interface type slot/port (for Cisco 7000 series) or interface type port (for Cisco 2500 series) to enter the interface configuration mode.
Example:
Router (config)#interface ethernet 0/1
Step 4: Enter the IP address and subnet mask of the interface using the ip address ipaddress subnetmask command.
Example,
Router (config-if)#ip address 192.168.10.1 255.255.255.0
Step 5: Exit the configuration mode by pressing Ctrl-Z
Router(config-if)#[Ctrl-Z]
Routing Protocol Configuration
Routing Information Protocol (RIP)
Step 3: Enter the router rip command
Router(config)#router rip
Step 4: Add the network number to use RIP and repeat this step for all the numbers.
Router(config-router)#network network-number
Example: Router(config-router)#network 192.168.10.0
Note: To turn off RIP, use the no router rip command.
Router(config)#no router rip
Other useful commands
• Specify a RIP Version
By default, the software receives RIP version 1 and version 2 packets, but sends only version 1 packets. To control which RIP version an interface sends, use one of the following commands in interface configuration mode:
To control how packets received from an interface are processed, use one of the following commands:
• Enable or Disable Split Horizon
Use one of the following commands in interface configuration mode:
Open Shortest Path First (OSPF)
Step 3: Enter the router ospf command and follow by the process-id.
Router(config)#router ospf process-id
Pick the process-id which is not being used. To determine what ids are being used, issue the show process command.
Router(config)#show process
Step 4: Add the network number, mask and area-id
Router(config-router)#network network-number mask area area-id
The network-number identifies the network using OSPF. The mask tells which bits to use from the network-number, and the area-id is used for determining areas in an OSPF configuration.
Example:
Router(config-router)#network 192.168.10.0 255.255.255.0 area 0.0.0.0
Repeat this step for all the network numbers.
To turn off OSPF, use the following command.
Router(config)#no router ospf process-id
• Configure OSPF Interface Parameters
You are not required to alter any of these parameters, but some interface parameters must be consistent across all routers in an attached network.
In interface configuration mode, specify any of the following:
Interior Gateway Routing Protocol (IGRP)
• Create the IGRP Routing Process
To create the IGRP routing process, use the following required commands starting in global configuration mode.
• Disable Holddown
The holddown mechanism is used to help avoid routing loop in the network, but has the effect of increasing the topology convergence time.
To disable holddowns with IGRP, use the following command in router configuration mode. All devices in an IGRP autonomous system must be consistent in their use of holddowns.
• Enforce a Maximum Network Diameter
Define a maximum diameter to the IGRP network. Routes whose hop counts exceed this diameter are not advertised. The default maximum diameter is 100 hops. The maximum diameter is 255 hops.
Use the following command in router configuration mode.
• To turn off IGRP, use the following command.
Router(config)#no router igrp autonomous-system
Border Gateway Protocol (BGP)
• Enable BGP Routing
Use the following commands in global configuration mode.
• Configure BGP Neighbors
BGP must completely understand the relationships it has with its neighbors.
• Reset BGP Connections
Use either of the following commands in EXROBOT.LK mode to reset BGP connections
• To turn off BGP, use the following command.
Router(config)#no router bgp autonomous-system
How to read router/link status
Status of router and links can be easily determined by power LED of router and link LED of each interface (if any). However, you may find a transceiver connected to an AUI port looks like the following:
When this transceiver is correctly connected, the “POWER” LED should light. Similarly, the “LINK” and “POLARITY” LEDs should light when you inserted the cable into the RJ45 socket on the transceiver. (Note that to get this result; the other end of the cable should be connected to some other devices as well.) If these LEDs are not light, you probably have problems with the link (cable).
Return to “Computer Networks”
