if (!preg_match("(^([-a-z0-9]+\.)+[a-z]{2,4}$)i", $domain)) echo "Domain name $domain is not valid"; Code: Select all
if (!preg_match("(^[-\w\.]+@([-a-z0-9]+\.)+[a-z]{2,4}$)i", $email)) echo "Email address $email is not valid"; Code: Select all
list($username, $domaintld) = split("@", $email, 2);
if (!getmxrr($domaintld, $mxrecords) OR !preg_match("(^[-\w\.]+$)", $username)) echo "Email address $email is not valid"; Code: Select all
$image_array = array_merge(array_diff($image_array,(array)$image)); Code: Select all
$image = $image_array[array_rand($image_array)]; Code: Select all
$text = preg_replace('#(_)+#','_',$text); Code: Select all
include($_SERVER['DOCUMENT_ROOT'] . '/file.inc'); Code: Select all
$user = $_SERVER['REMOTE_USER']; Code: Select all
putenv('TZ=EST5EDT'); // eastern time Code: Select all
echo $_SERVER['QUERY_STRING']; Code: Select all
echo "Last modified: ".date ("F d, Y", getlastmod()); Code: Select all
$newArray = preg_replace("#\r\n?|\n#","",file('file.txt')); Code: Select all
$output = strtr($output,array('&'=>'&','<'=>'<','>'=>'>'));
