hello, again lol neo and everybody,
i'm wondering about something, i've got a chat script that doesnt use mysql, its flat based no mysql used
all the messages go into msg.html so after time you know this will fill the html into Mbs to gigabytes
how would i delete everything inside msg.html through php ?
or can i delete msg.html and recreate msg.html through php ? is this possible,
php delete and create ?
Re: php delete and create ?
i find this
so i would make , for example
cleanMessages.php
it will just overwrite the msg.html and thus clean it ?
$ourFileName = "testFile.txt";
$ourFileHandle = fopen($ourFileName, 'w') or die("can't open file");
fclose($ourFileHandle); cleanMessages.php
<php?
$ourFileName = "msg.html";
sorry i've figured it out already
i will use ajax with mootools or jason to reload url cleanMessages.php every 10 mints thus cleans msg.html
Can it be that "testFile.txt" holds the real list of messages and the HTML is just used for viewing on the browser ?
If that is the case you would open it as you have noted.
However, You might need to think of a free php based shout box which automatically handle this.
chat.php
[/code]
it looks like just opens msg.html and adds msg i think. i could probably change that to messages.txt
its ok i figured a wayyy better way to fire cleanMessages.php using Online cron jobs, so every 15 mints it will clean it
yes i thought about adding some shoutbox but the thing is, most of them are really ugly and not simple to use for example
every shoutbox, requests that you add your name,website,email,then message
in my shoutbox, you only add ur nickname, and type messages simple as that.
session_start();
function createForm(){
<form action="<?php echo $_SERVER['PHP_SELF']; ?>" method="post">
<table align="center">
<tr><td colspan="2">Please eneter a nickname to login!</td></tr>
<tr><td>Your name: </td>
<td><input class="text" type="text" name="name" /></td></tr>
<tr><td colspan="2" align="center">
<input class="text" type="submit" name="submitBtn" value="Login" />
</td></tr>
</table>
</form>
if (isset($_GET['u'])){
unset($_SESSION['nickname']);
// Process login info
if (isset($_POST['submitBtn'])){
$name = isset($_POST['name']) ? $_POST['name'] : "Unnamed";
$_SESSION['nickname'] = $name;
$nickname = isset($_SESSION['nickname']) ? $_SESSION['nickname'] : "Hidden";
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "DTD/xhtml1-transitional.dtd">
<html>
<head>
<title>Micro Chat</title>
<link href="style/style.css" rel="stylesheet" type="text/css" />
<script language="javascript" type="text/javascript">
var httpObject = null;
var link = "";
var timerID = 0;
var nickName = "<?php echo $nickname; ?>";
// Get the HTTP Object
function getHTTPObject(){
if (window.ActiveXObject) return new ActiveXObject("Microsoft.XMLHTTP");
else if (window.XMLHttpRequest) return new XMLHttpRequest();
else {
alert("Your browser does not support AJAX.");
return null;
// Change the value of the outputText field
function setOutput(){
if(httpObject.readyState == 4){
var response = httpObject.responseText;
var objDiv = document.getElementById("result");
objDiv.innerHTML += response;
objDiv.scrollTop = objDiv.scrollHeight;
var inpObj = document.getElementById("msg");
inpObj.value = "";
inpObj.focus();
function setAll(){
objDiv.innerHTML = response;
// Implement business logic
function doWork(){
httpObject = getHTTPObject();
if (httpObject != null) {
link = "message.php?nick="+nickName+"&msg="+document.getElementById('msg').value;
httpObject.open("GET", link , true);
httpObject.onreadystatechange = setOutput;
httpObject.send(null);
function doReload(){
var randomnumber=Math.floor(Math.random()*10000);
link = "message.php?all=1&rnd="+randomnumber;
httpObject.onreadystatechange = setAll;
function UpdateTimer() {
doReload();
timerID = setTimeout("UpdateTimer()", 5000);
function keypressed(e){
if(e.keyCode=='13'){
doWork();
</script>
</head>
<body onload="UpdateTimer();">
<div id="main">
<div id="caption">Micro Chat</div>
<div id="icon"> </div>
if (!isset($_SESSION['nickname']) ){
createForm();
} else {
<div id="result">
$data = file("msg.html");
foreach ($data as $line) {
echo $line;
</div>
<div id="sender" onkeyup="keypressed(event);">
Your message: <input type="text" name="msg" size="30" id="msg" />
<button onclick="doWork();">Send</button>
</div>
</div>
</body>
messages.php
[code=php]
if (isset($_GET['msg'])){
if (file_exists('msg.html')) {
$f = fopen('msg.html',"a+");
} else {
$f = fopen('msg.html',"w+");
$nick = isset($_GET['nick']) ? $_GET['nick'] : "Hidden";
$msg = isset($_GET['msg']) ? htmlspecialchars($_GET['msg']) : ".";
$line = "<p><span class=\"name\">$nick: </span><span class=\"txt\">$msg</span></p>";
fwrite($f,$line."\r\n");
fclose($f);
echo $line;
} else if (isset($_GET['all'])) {
$flag = file('msg.html');
$content = "";
foreach ($flag as $value) {
$content .= $value;
echo $content;
it
