CREATE TABLE IF NOT EXISTS `table` (
`ip` text NOT NULL,
`online` text NOT NULL
`hits` text NOT NULL
) ENGINE=MyISAM DEFAULT CHARSET=latin1
// MySQL Connection
$connect = mysql_connect( 'localhost', 'username', 'password' ) or die(mysql_error());
mysql_select_db( 'database' );
$ip=$_SERVER['REMOTE_ADDR'];
$timestamp = time();
// checks if IP is in database
$getStats2 = mysql_query("SELECT * FROM `table` WHERE `ip`='$ip'") or die(mysql_error());
if( mysql_num_rows( $getStats2 ) == 0 )
$select2 = mysql_query("INSERT INTO `table` (`ip`, `online`, `hits`) VALUES ('$ip','$timestamp','1')") or die(mysql_error());
else {
// checks to see if last hit was before or after 24 hour mark.
$diff = time() - 86400;
$counthits = mysql_query("SELECT * FROM `table` WHERE `online` > '$diff' && ip='$ip'") or die(mysql_error());
if (mysql_num_rows($counthits)==0){
// unique hit
while ($t=mysql_fetch_array($counthits)){
$hits=$t['hits'];
//checks if there is 5 hits yet...
if ($hits=="5"){
// do message!
else {
$select2 = mysql_query("UPDATE `table` SET `online` = '$timestamp', `hits`=`hits`+1 WHERE `ip` = '$ip'");
else {
//not unique, does nothing...
