How to implement an accurate rating system
Re: How to implement an accurate rating system
Good to hear that Asaf. Spread the message of ROBOT.LK among your friends & colleagues as much as possible. Encourage humans to share knowledge and help each other which will make this world a better place for everyone.
Hello Saman,
giving the table you have suggested:
ITEM | TOTAL_NUMBER_OF_VOTES | TOTAL_RATING
I need a MySQL statement that will do everything you said:
1. update new rating of an existing item in the rating table (update and select of current NUMBER _OF VOTES and THIS_RATING in one statement).
2. insert a new rating of a new item in the rating table.
is it possible to do it in one statement?
I tried something like:
UPDATE tbl_RATING SET NUM_OF_VOTES = ((select NUM_OF_VOTES from tbl_RATING where ITEM=5) +1)
WHERE (((tbl_RATING.ITEM)=5))
but it didn't work...
It seems you are lacking knowledge on SQL and databases. To work with databases you need to have a good knowledge on database design & normalisation principles with SQL. You can refer the following books to get a good idea.
Fundamentals of Database Systems (4th Edition) by Elmasri & Navathe - This book is simple to understand. Highly recommended for a beginner.
An Introduction to Database Systems by C. J. Date - This is usually used as the standard university reference which covers almost all fields of database systems. However this is a bit advance book.
You can update both fields at ones.
If you have more database related questions, could you please submit them under Computer Science ‹ SQL & Database.
UPDATE tbl_RATING
SET NUM_OF_VOTES = NUM_OF_VOTES + 1, TOTAL_RATING = TOTAL_RATING + 1
WHERE tbl_RATING.ITEM = 5Re: How to implement an accurate rating system
Hi Saman,
first of all thank you very much for you advice.
please tell me what do you think of my code.
there are two functions setRating and getRating.
the DB tables are:
table: tbl_RATING:
ITEM | TOTAL_NUMBER_OF_VOTES | THIS_RATING (average votes for this item)
table: tbl_TOTAL_RATING:
AVG_NUM_VOTES | AVG_RATING
I will be happy to hear any comment you have.
the DB tables are:
table: tbl_RATING:
function setRating(ItemID, iRating)
on error resume next
setRating = False
if not IsNumeric(ItemID) or not IsNumeric(iRating) then
exit function
end if
dim oConnection
oConnection = openConnection ()
if not oConnection then
exit function
end if
Dim mySQL
mySQL = "SELECT COUNT(1) as numberOfRecords FROM tbl_RATING WHERE ITEM = " & ItemID & " "
Dim rs ' RecordSet object
set rs=Server.CreateObject("ADODB.recordset")
rs.Open mySQL, oConnection
if CLng(rs("numberOfRecords")) > 0 then ' item found, update item
mySQL = "UPDATE tbl_RATING SET tbl_RATING.NUM_OF_VOTES = (NUM_OF_VOTES+1), RATING = ((tbl_RATING.NUM_OF_VOTES * tbl_RATING.RATING)+" & iRating & ")/(tbl_RATING.NUM_OF_VOTES+1) WHERE tbl_RATING.ITEM=(" & ItemID & ") "
else ' no item found, insert new item
mySQL = "INSERT INTO tbl_RATING (NUM_OF_VOTES, RATING, ITEM) VALUES (1, " & iRating & ", " & ItemID & ") "
end if
rs.Close
oConnection.execute(mySQL)
mySQL = "SELECT AVG(NUM_OF_VOTES) as avgNumOfVotes, AVG(RATING) as avgRating FROM tbl_RATING GROUP BY NUM_OF_VOTES "
if rs.EOF =true and rs.BOF=true then ' no item found
rs.Close
Set rs = Nothing
closeConnection (oConnection)
exit function
end if
dim avgNumOfVotes, avgRating
avgNumOfVotes = rs("avgNumOfVotes")
avgRating = rs("avgRating")
rs.Close
Set rs = Nothing
Application.Lock
Application("AVG_NUM_VOTES") = avgNumOfVotes
Application("AVG_RATING") = avgRating
Application.Unlock
'update total rating
mySQL = "UPDATE tbl_TOTAL_RATING SET AVG_NUM_VOTES = " & avgNumOfVotes & ", AVG_RATING = " & avgRating & " WHERE 1"
end function
function getRating(ItemID)
getRating = ""
if not IsNumeric(ItemID) then
exit function
end if
dim oConnection
exit function
end if
mySQL = "SELECT NUM_OF_VOTES, RATING FROM tbl_RATING WHERE ITEM =(" & ItemID & ") "
rs.Close
Set rs = Nothing
exit function
end if
dim numOfVotes, rating
numOfVotes = rs("NUM_OF_VOTES")
rating = rs("RATING")
rs.Close
Set rs = Nothing
'br = ( (avg_num_votes * avg_rating) + (this_num_votes * this_rating) ) / (avg_num_votes + this_num_votes)
getRating = ( CLng(Application("AVG_NUM_VOTES")) * CLng(Application("AVG_RATING")) ) + ( CLng(numOfVotes) * CLng(rating) ) / ( CLng(Application("AVG_NUM_VOTES")) + CLng(numOfVotes) )
end function
Hi, sorry for taking lot of time to give you a reply. The reason was robot.lk wasn't working due to a server repair I guess.
I see you are writing using VBScript, Is that right? Have a look at following VBScript ADO example and use it as a guideline.
In your code, I don't see you have opened a connection to a database. Here we have opened a connection to an MS Access database as follows.
If you are using MS SQL Server, you can use the following connection string.
After that I do see lots of SQL syntax errors & places where we can improve the efficiency in your code but it really takes quite a lot of time of mine to explain all these things. I'll brief them as I can.
A.
Can be simply used as,
When you accessing a single table using SQL, you don't need to put table name in-front of fields. This will improve readability.
B.
Should not group since you need the average of all. Don't you?
You need to improve your SQL knowledge. In cases where you need to handle about 5 tables linked together using different join methods to output a recordset you will find difficulties. If you are going to be on the field of database programming, SQL knowledge is a must.
I would like to ask you to write a little introduction about yourself under Member Area -> Introduction to know you better.
' Define our variables which will be used as references to our ActiveX Data Objects
Dim con
Dim rst
' Create two strings for use with the creation of a connection and a recordset
Dim sConString
Dim sSQLString
' Create a new instance of an ADO Connection object
Set con = Server.CreateObject("ADODB.Connection")
Response.Write "Connection object created.<BR>"
' Open the Mydb data source (Access database) with the Connection object
sConString = "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=C:\\My DB\\Mydb.mdb"
con.Open sConString
Response.Write "Connection opened.<BR>"
' Create a Recordset object from a SQL string
sSQLString = "SELECT TOP 10 Author FROM Authors"
Set rst = con.Execute(sSQLString)
Response.Write "SQL statement processed.<BR>"
' Retrieve all the data within the Recordset object
Response.Write "Getting data now...<BR><BR>"
Do Until (rst.EOF)
Response.Write rst("Author") & "<BR>"
rst.MoveNext
Loop
Response.Write "<BR>End of data.<BR>"
' Close and remove the Recordset object from memory
rst.Close
Set rst = Nothing
Response.Write "Closed and removed Recordset object from memory.<BR>"
' Close and remove the Connection object from memory
con.Close
Set con = Nothing
Response.Write "Closed and removed Connection object from memory.<BR>"
con.Open sConString
sConString = "Provider='sqloledb'; Data Source=ServerName; Integrated Security='SSPI';Initial Catalog='Mydb';"
A.
mySQL = "UPDATE tbl_RATING SET NUM_OF_VOTES = (NUM_OF_VOTES + 1), RATING = ((NUM_OF_VOTES * RATING) + " & iRating & ")/(NUM_OF_VOTES + 1) WHERE ITEM = (" & ItemID & ")"
B.
mySQL = "SELECT AVG(NUM_OF_VOTES) as avgNumOfVotes, AVG(RATING) as avgRating FROM tbl_RATING GROUP BY NUM_OF_VOTES"
mySQL = "SELECT AVG(NUM_OF_VOTES) as avgNumOfVotes, AVG(RATING) as avgRating FROM tbl_RATING"
