What Is Adobe Flex?
Posted: Wed Nov 25, 2009 5:36 pm
by Cyclops
What Is Adobe/Macromedia Flex?
As a web developer you've often found yourself wishing there was a way to make web applications that weren't limited to the heavy restrictions of HTML. You've used JavaScript to make your forms a little more intuitive with dynamic/context driven comboboxes, but to do anything more often requires heavy amounts of JavaScript and DHTML. Even if you are a pro at it, it's extremely time consuming to make workflow interactive and user friendly. More importantly, why would you want to be spending so much time on core UI functionality when you're getting paid to work on business logic and workflow.
Adobe/Macromedia Flex takes you to the next level of web application development with the concept of Rich Internet Applications (aka RIAs). You may have seen applications developed natively in Flash itself and realized that it offers a much more robust experience for the user where productivity is bolstered by ease of use, streamlined workflow, and real time interactivity that is impossible to accomplish in HTML itself. However developing rich applications in Flash for those who are core developers is daunting and unintuitive. The Flash development tool is geared for designers, and developing on a timeline is a strange concept. Flex removes that barrier to entry by providing a programmatic way for developing these RIAs.
What is an RIA anyways? Well HTML applications are state-less. Application servers maintain state by using cookies and session variables to keep track of users, but all the logic is on the server. So while a user is looking at a page in their browser, the application is unable to do anything until the user commits an action that sends data from the page back to the server for processing. The code processes the data, and generates resulting HTML that the browser loads back in.
A simple example would be a report or search tool that queries a sales/CRM database based on various criteria from the user such as deal time frame, product group, and sales executive. The user enters these values, clicks on a submit button, and the browser goes blank while it waits for a response from the server and loads the resulting HTML which would be a tabular list of records that match the criteria:
Look familiar to anything you've done? Now if the user wants to change the parameters, or perhaps sort on a particular column, typically the page would need to be sent back to the server where it rebuilds an up to date report based on the new criteria. Pretty standard stuff for Coldfusion, JSP, PHP, ASP, or any other servlet language.
In the Flex world, your application wouldn't need to post a request to the server every time the user made a change. Instead of the logic living purely on the server side, your presentation tier is all on the client. So imagine changing filters or criteria, and the table automatically updating as a result. Imagine clicking on a column title and the column automatically sorts without reloading the page. This saves hits to your web server, application server, database, and network. For one user this may not be a big deal, but what about 1000 users, or 10 000 users?
HTML based applications are a series of HTML web pages; Flex applications are LIVE applications. A simple analogy is imagine Word or Excel being an HTML web application; vs the real application itself. It could be done; but the real application is aware of your mouse movements, every key stroke, and provides much more feedback to the user by using sound, animation, and other visual queues.
Even better, with the Flash Player penetration near 99% (version 7 is at 83%) you can provide this real-time rich experience on Unix, Windows, and MAC. Alternatively any richness you try to accomplish in IE using DCOM, ActiveX, and DHTML locks you down to particular platforms.
Flex vs Coldfusion (and other servlets)
For CFMX developers, Flex doesn't replace CF (or JSP/J2EE/PHP/ASP/etc...). It's a companion to your existing technology by being at the presentation tier, while your other Application servers provide the middle/business tier. It lets you focus on the client workflow, and not waste time building HTML tables and endless cosmetic logic.
I put together a simple example that demonstrates this, which you can download here. The attached file provides a static XML file; but you easily hook it up to a CF template which queries a database based on the parameters passed in via the URL and return back the up to date HTML.
The first example which uses Coldfusion:
It does a CFHTTP to the XML provider by passing in the sort direction parameters based on what column a user clicked on. After parsing the XML, it loops through the XML array with some basic styling to do alternating row colors. It's roughly 40 lines or so, depending on how compact or readable you want to make your code.
The second example which uses Flex:
Since my web hosting company doesn't provide Flex hosting I can only provide screen captures. The Flex version retrieves the exact same XML content as the Coldfusion one would. However the key notes to make in the above example are:
1. The Flex version is 2 lines of code.
2. The Flex version's columns are sortable AND re-sizeable with no page refreshing required.
3. No time is wasted building basic UI elements (that is tables).
Another common scenario we're all used to is list & edit. As demonstrated above, often you'll use a table to list data, and then present the user with an edit icon which let's you edit that record, which posts a URL to the server, where the browser loads in an edit page where you make the appropriate changes, then hit submit, the server processes the update and then sends back the resulting HTML. That's a mouthful! Why not edit right in the table itself; much like you would with Excel?
The folks at iteration:two in their Flex Blog demonstrate this capability. Click on any row and you'll see how it's immediately editable. Since the application is live you don't need that common update/submit button to post that change; the application knows an update was made and can commit those changes on the backend if nescessary.
The hidden beauty is that your Flex app can tap into your Coldfusion CFC's as a WebService or RemoteObject with no extra work required. So use Coldfusion to work with backend systems like databases, and provide services to the presentation tier. And use Flex to handle interacting with the client.
Flex VS AJAX
The mindset you need to employ is that Flex is used for Rich Internet Applications, not Rich Web Applications. There isn't a clear line between RIAs and RWAs, but Flex is definitely on the RIA side of things in that you are building applications that are desktop like but use the internet for deployment ease and connectivity to services. Unlike AJAX, which is more along the RWA end of the spectrum in that it increases functionality and usage efficiency of web pages.
The roots of HTML originate as platform agnostic document distribution, and it vastly improved how content can be deployed, but severely compromised on UI functionality since it's a stateless mechanism. A web application is essentially a choose your own adventure book, where the choices you make generate new pages in your book on the fly. Although there is overlap in how Flex or AJAX could be used to solve a problem, there is also quite a bit of difference.
Think of it like this. If you were to build a photo editor, what would you choose? HTML is optimized for document distribution, so although it could be done in AJAX using an army of developers - it's clearly the wrong choice. Flex on the other hand has desktop like powers, so making such a graphically oriented application is fairly straight forward. Or what if you wanted to make an application that allows users to update their profile by clicking on a button that takes a picture from their webcam - this is extremely easy in Flex, and impossible in HTML/AJAX. Or a stock application; in AJAX you would continuously poll for updates in the stock symbols the user is interested in (even if there is no change in price), compared to the Flex approach where the client would use messaging to subscribe to the applicable symbols, and the Flex Enterprise Server would push updates as they occur.
AJAX's other drawback is that because Javascript differs from browser to browser and OS to OS, a massive amount of QA needs to be done to ensure that it works across all platforms. But to be fair there is a major effort to provide tools and APIs to abstract that complexity, and streamline the development of AJAX based applications. Most notably the Open AJAX Initiative which is supported by such heavyweights as IBM, BEA, Borland, Google, Mozilla, Oracle, RedHat, and Yahoo.
So to boil it down Flex and AJAX are like apples and oranges, but they're both fruit so they share some characteristics.
Developing in Adobe/Macromedia Flex
So that's all well and dandy, but how long does it take to learn all this stuff? Flex uses a combination of a tagged based language called MXML, and an object oriented language called Actionscript 2.0 (the language of Flash). For Coldfusion and JSP developers the MXML part is immediately understandable. The Actionscript part will be familiar to Java, and other OO developers.
You build your main files in .mxml, and can build custom components and objects in .as (ActionScript). The Flex Application Server (a J2EE application) will compile your code into a Flash file (.swf) which the browser then loads. The Flex App server provides other services such as being a gateway to RemoteObjects (eg CF CFCs) and WebServices.
Although you can use any text editor to develop, FlexBuilder is the primary development tool - which is a customized version of DreamWeaverMX. On the debugging front you can use certain components such as XMLObject which comes with Flex, flash debugging, and the NetConnection Debugger which lets you analyze data between RemoteObjects and the Flash Player (ie your Adobe/Macromedia Flex Application).
Flex isn't billed as RAD (Rapid Application Development); it's geared towards Enterprise Applications where the real-time interactivity and rich workflow are the primary ROI. However developing in Flex is by far faster than developing productivity tools in Flash natively; on some accounts there are development speed gains of 10X.
Flex out of the box comes with various pieces such as navigators (tree, accordian, tab), charting/graphing components, components such as the infamous datagrid, and effects such as fades and wipes. They're easy to use and often require just passing it data and it handles the presentation on its own. All of these can be customized to suit your purposes.
The sky is really the limit when it comes to RIAs. Imagine dragging and dropping an item for sale into a shopping cart instead of clicking on the old school [add to cart] button. This type of functionality is easy to implement. Or the whole realm of sound; where you can provide audio guided applications that talk users through their first time in the workflow.
Also consider the case of something like a dashboard such as a Network Monitoring Application, or Stock monitor. In the HTML scenario, if the data refreshes frequently, you would probably be meta-refreshing that page constantly, and again pounding databases for up to the date data. In the Flex scenario, since you can create stateful applications, the clients only need to load an initial set of data once - and the middle tier can just push/broadcast deltas or updates (Flash Communication Server comes in handy in this case).
One of the best examples out there is provided by Macromedia (now known as Adobe), called the Flex Store. Try dragging and dropping an article into the basket. Or play with the price range slider; the workflow benefits are immediately recognizeable. Two other interesting examples include the Restaurant Finder from Chrisophe Coenraets where you slide a box around a map to see restaurants in the area, and the other being the Brocade Sales Dashboard (click on measure viewer, and then a company on the bar graph). For more examples see the Community Adobe/Macromedia Flex home page.
Limitations
Flex applications are Flash applications, and are limited by what the Flash player can do.
1. The Flash Player is not a web browser. So producing rich documentation is challenging. That is what HTML was specifically designed for.
2. Flash/Flex popup windows are limited to being displayed within the dimensions of the instance of the player that created it. So unlike a popup window in a browser which you can move to anywhere on your desktop, your Flex/Flash popup windows can't move outside the area occupied by the player. This is actually quite a severe limitation if you want to maximize on desktop real-estate (especially for users that have multiple monitors). There are workarounds in that you can use Flex's Javascript to Actionscript API to popup new instances of the player in browser windows, and use Javascript to act as a communication bridge - however the effort is rarely justified. The removal of this limitation is dependent on the Apollo Player (aka the Universal Client) - which will allow Flex/Flash apps to run and behave completely like a desktop application without having to live inside a browser.
3. Drag and Drop from Desktop to Player is not supported. This may become possible with Apollo, but for now the goal of the Flash player is to remain as lightweight as possible and platform agnostic. Being able to drag a file from your desktop on the player (to say initiate an upload) would require OS specific support.
4. The Flash SWF format is a published specification - so it is possible for other vendors to make tools that generate Flash files. However the future of the Flash platform is controlled by a single organization (Adobe/Macromedia), unlike open or collaborative intitiatives. But to mitigate that Adobe has been extremely open in allowing the community to direct the future of the platform (Flex 2 is the result of public alpha and beta programs).
5. Because Flex applications are thin clients, and not web pages they're not suitable for where you want to use a web page. I.e, there is an initial load and intialization that occurs when running a flex application initially, so the user could have to wait 5-10 seconds as the application gets set up, and once its loaded you're rocking and rolling. Similar is the case with desktop applications.
