How can I get different types output in C?
Nandika
Post by Nandika » Wed Oct 24, 2012 11:19 am
Hello Friends,
I coded small program using C (with C Free 5)
#include <stdio.h>
int main(){
	float f;
	f=5/2;
	printf ("%f",f);
Print result is 2.000000 :?: What is the error in my code?
I wished 2.5 :(
I already found some about printf() command.according to this table.
Conversion letters.
Conversion letters.
Cant I use this Conversion letters with variables?
Nandika
Re: How can I get different types output in C?
Post by Nandika » Wed Oct 24, 2012 2:24 pm
ok Now I have a Solution ....
cording was modified as this,
#include <stdio.h>
int main(){
   float f;
   f=5.0/2.0;
   printf ("%f",f);
As I think,
My assumption is,
This is a Compiler's misunderstand...(it is so mad :lol: ) :idea: :idea: :idea:
My opinion is,
if number is wrote as 5 compiler get it as an integer..therefore,output was integer.
if 5.0 compiler get it as a float...therefore output was float
Is My assumption correct? :x
Post by Neo » Fri Oct 26, 2012 10:26 am
No. It is not the compiler. Compiler has done a correct thing here.
Integers and Real (floating point) numbers are treated in this way by compilers.
When you divide 5/2, these are two integers you need to divide. So the result is an integer.
What you have to do here is to inform the compiler that you need a Real (floating-point) division rather than an integer division. To do that, it is enough to make one of the numbers to be Real such as 5.0/2 or 5/2.0. So compiler knows what you want.
Try this:
float a = 5;
float b = 2;
float c;
c = a / b;
You will see that 'c' returns 2.5 as expected. The reason is, since you used 'a' and 'b', the compiler knows you need a Real division.
Hope this is fully clear now.
Nandika
Post by Nandika » Fri Oct 26, 2012 10:48 pm
Thank you Neo....
Now fully clear my problem . :)
This code also work well,
#include<stdio.h>
int main(){
	float a=5;
	float b=2;
	float c;
	c=a/b;
	printf("%f",c);
	return(0);
Herath
Post by Herath » Sat Oct 27, 2012 7:22 pm
I am using it in the short form like the following,
#include <stdio.h>
int main(){
   float f;
   f=5/2.0;
   printf ("%f",f);
Note the "2.0". :) . You could make either one of them as float.
-- Sorry it has already been answered. I did not read the whole thing except the codes.
Post by Neo » Sat Oct 27, 2012 7:41 pm
Nice to see our great Herath is also back in to business!!!!
Herath
Post by Herath » Sat Oct 27, 2012 7:43 pm
Been checking the forum, but haven't been involving much. :)
Hi :D
Nandika
Post by Nandika » Wed Oct 31, 2012 2:57 pm
Thank you Herath for your reply... :)
Return to “C/C++ Programming”
