Analysis and Design of the Extrusion Process
Posted: Fri Oct 30, 2009 1:08 am
by Magneto
Conventionally, die design for a new extrusion was developed from previous experience and through costly experimentation and in-plant trials. Thus, process and die development required relatively long periods of time and disturbed regular production.
Some semiempirical analytical techniques have been developed for computer-aided design of extrusion dies. However, these techniques are approximate and could be vastly improved by developing FEM-based computer programs for metal-flow simulation.
A scientific design of the extrusion process could use FEM to establish the following variables [52]:
Optimum number of shaped orifices in the die, e.g., in aluminum extrusion several sections are often extruded simultaneously
Location of the orifices relative to the billet axis for uniform flow through each orifice
Orientation of the orifices
Modification of the shape of the orifices to correct for thermal shrinkage and die deflection under load
Determination of die bearing lengths for balancing metal flow to avoid the twisting and bending of the extrusion emerging from each orifice
Determination of the extrusion load: quite difficult since the extruded sections are usually nonsymmetrical, resulting in a complex 3D metal flow in the deformation zone
A small-strain 2-D (axis-symmetric) elastic-plastic finite-element analysis was used to study this process. The material (commercially-pure aluminum) was assumed to be extruded slowly and under isothermal conditions, with the yield stress depending only upon strain.
In Fig. 1, metal flow pattern was simulated with the FEM, during which beta-stiffness friction model was used, with a value of friction factor m = 0.7 employed to correspond with unlubricated contact between the billet and the container and punch.
As illustrated in Fig. 2, the ultimate process and die design in forging requires non-isothermal flow simulation via 2D and 3D FEM techniques. Thus, dies can be designed better and the need for experimentation is reduced.
