Want to design a flange coupling ...
Posted: Mon Apr 05, 2010 9:42 pm
by lasarpk
Hi All ,
I want to design a cast iron flange coupling to transmit power from a electric motor to a ball mill.
rated power output of motor is 90 KW at 250 rpm. Both motor and ball mill shafts have made outof mild steel.
Can any body tell me how to design this please ?
basically I want folowing
1. Hub design
2. Key design
3. Flange design
4. bolts design
Re: Want to design a flange coupling ...
Posted: Wed Apr 07, 2010 12:33 pm
by Jane
We would love to assist you
But before that, could you tell me your background a bit.
You might know that this subject requires a certain amount of knowledge in advance mathematics in mechanical engineering.
So we do answer to questions to suit your knowledge and background. It is quite useless for us to explain you things that you don't understand.
So the first thing is tell us about you. Based on that we will try our best to assist you one step at a time. Note that we will only assist you, you will have to do the thing and report us back so we move on to next step and so on....
Regards...
Posted: Wed Apr 07, 2010 9:06 pm
by lasarpk
I have a diploma in mechanical engineering and familiar with basic principals in statics and dynamics
Posted: Wed Apr 07, 2010 10:28 pm
by Magneto
Dear Friend ,
Here is the detail design for Flange Coupling Step by step. If you have any problem with this solution , just drop it in
robot.lk. As robot.lk team , we are always with you for solving your technical problems.
- 1.JPG (40.67 KiB) Viewed 23816 times
- 2.JPG (61.67 KiB) Viewed 23816 times
- 3.JPG (51.97 KiB) Viewed 23816 times
Good Luck !
Posted: Thu Apr 08, 2010 7:02 am
by lasarpk
Dear Magneto ,
Thanks for your very clear and step by step answer. I got the stuff. I was searching a solution for this problem in the Internet for last few days and unable to find any good one.
And by the way are you a mechanical engineer or electronic engineer or electrical engineer or control engineer or computer engineer ?
Because I have seen in the forum that you have given nice answers to the problems of all of those fields .
Posted: Thu Apr 08, 2010 10:12 am
by Magneto
Dear Friend ,
My basic degree is from mechanical engineering and after that I did masters in electronics.
My most like field is control engineering. By profession I am a electronic engineer.
