Arduino UNO Original Development Board with USB Cable
Arduino UNO Normal Development Board with USB Cable
Arduino UNO Enclosure Box
Arduino MEGA Original Development Board with USB Cable
Arduino MEGA Normal Development Board with USB Cable
Arduino Mega Enclosure Box
Arduino Due Development Board with USB Cable
Arduino Nano V3.0 Normal CH340G Mini USB
Arduino ATTiny85 General Development Board
Raspberry Pi 3 Model B
Raspberry Pi Transparent Enclosure Box
Raspberry Pi Zero 1.3
PIC K150 Microcontroller Programmer
PICkit3 Microchip Programmer
PICkit2 Microchip Programmer
ATMega32 ATMega16 AVR ISP Minimum System Development Board
USBISP AVR ISP Programmer with 10-Pin Cable
10-Pin to 6-Pin Converter for Atmel AVR ISP Programmer
HC-SR04 4Pin Ultrasonic Sensor Module
HY-SRF05 HC-SR05 5Pin Ultrasonic Sensor Module
JSN-SR04T Waterproof Ultrasonic Distance Measuring Module
HC-05 Bluetooth Wireless Serial Arduino Module
HC-06 Bluetooth Wireless Serial Arduino Module
433Mhz Wireless RF Transmitter Receiver Module Kit for Arduino
HC-12 SI4463 868MHZ High Power Wireless Transceiver Arduino
RFM69HW RFM12B 433Mhz Wireless Transceiver Module
LR35B 315MHz 150m 4.5V 5V 3.5mA ASK Superheterodyne Wireless Receiver Module
4-Channel 315MHz Wireless RF Remote Controller with Receiver
NRF24L01 2.4GHz Wireless Transceiver Module
NRF24L01+PA+LNA 2.4G Wireless Transceiver Module with SMA Antenna
ESP8266 ESP-07 WiFi Transceiver Wireless Module (Only Chip)
NodeMCU ESP8266 WiFi ESP-12E CH340 IoT Dev Board Module
NodeMCU ESP8266 Base Interface Testing DIY Board
RTL8710 WiFi Wireless SOC Transceiver Arduino
RTL8710 WiFi Transceiver Module Test Development Board for Arduino
ENC28J60 Ethernet Module for Arduino
W5100 Ethernet Shield for Arduino
RC522 13.56Mhz RFID Module Kit for Arduino
RC522 13.56Mhz RFID Module for Arduino (Square)
PN532 NFC RFID Module V3 Kits Reader Writer for Arduino
EM4100 RDM6300 RDM630 125KHz RFID Card Reader Module
EM4100 HZ-1050 125KHz RFID Precise Reader Module
HID-005 RFID Secure Card Reader
RFID ID Card Reader Password Keypad Door Lock Access Control Unit
Smart Card RFID 125KHz
RS232 Serial to TTL Converter Module MAX3232
CH340 RS232 USB To TTL Converter Module Adapter
MAX485 TTL to RS485 MAX485CSA Converter Module for Arduino
CN480661 RS232 USB To TTL Converter Module Adapter
ACS712T Chip TTL to RS485 Converter Module
XY-017 UART TTL to RS485 3.3V 5V Module for Arduino
FT232RL USB to TTL Converter Module Adapter Mini USB
USB To RS232 Cable
DB9-G6 RS232 Nut Type Connector 9Pin Male Adapter Terminal Module
LM393 Touch Detection Sensor Module for Arduino Smart Car
4x1 4-Channel Digital Capacitive Touch Sensor Module
4x2 8-Channel Digital Capacitive Touch Sensor Module
4x4 16-Channel Digital Capacitive Touch Sensor Module
Gamepad JoyStick Keypad Shield For Arduino nRF24L01
Thumb Joystick Module for Arduino
ACS712 5A Current Sensor Module for Arduino
1x4 4-Key Membrane Switch Keypad Module
4x4 16-Key Membrane Switch Keypad Module
801S Vibration Sensor Switch Detection Module for Arduino
801S Vibration Sensor Switch Detection Sensor
HC-020K Wheel Speed Counting Sensor Encoder Kit
3144E Hall Switch Speed Counting Position Sensing Module
PCF8591 ADC and DAC Module for Arduino
Arduino 6-bit LED Module Multi-colour
IIC/I2C/TWI/SPI Serial Interface Board Module Port for 1602 LCD Display PCF8574T
2.4 inch 176x220 TFT LCD Display Touch Screen Shield Module for Arduino
1602 16x2 LCD Keypad Shield Module for Arduino
Infrared IR Receiver and Wireless Remote Control Kit for Arduino
Line Hunting Sensor Module with Preset 3-pin TCRT5000 for Arduino
Line Tracking Sensor Module without Preset TCRT5000 for Arduino
OV7670 VGA 640x480 0.3Mega CMOS Camera Module for Arduino
SHARP GP2Y0A21YK0F Infrared IR Sensor (10- 80cm)
ST GY-VL53L0XV2 Time of-Flight Distance Sensor
HC-SR501 PIR Sensor Module for Arduino
24VDC 15 Way 15 Channel Wireless Remote Control Relay Module
5VDC 1 Way 1 Channel Relay Module With Coupling Protection
5VDC 2 Way 2 Channel Relay Module With Coupling Protection
5VDC 4 Way 4 Channel Relay Module With Coupling Protection
5VDC 8 Way 8 Channel Relay Module With Coupling Protection
L298N Motor Driver Module for Arduino (Normal)
L298N Motor Driver Module for Arduino (Original)
ULN2003 Stepper Motor Driver Module 5V 12V for Arduino
Raindrops Rain Sensor Moisture Water Module YL-83 FC-37
HX711 Dual-channel 24-bit AD Conversion Weighing Sensor Module for Load Cell
Load Cell 20Kg
5000Kg capacity S-Type load cell
DS18B20 Waterproof Digital Temperature Sensor Probe with 1m Cable
DHT11 Temperature and Relative Humidity Sensor Module for Arduino
CJMCU-101 OPT101 Light Intensity Sensor Module
BMP180 4-pin 1.8V to 6V Digital Barometric Pressure Temperature and Altitude Sensor for Arduino
BMP180 5-pin 1.8V to 5V Digital Barometric Pressure Temperature and Altitude Sensor for Arduino
L3G4200D Triple Axis Digital Gyroscope Angular Velocity Sensor Module
MPU-6050 Triple Axis Analog Accelerometer Gyroscope Module
ADXL345 Triple Digital Accelerometer Module for Arduino
ADXL335 Triple Digital Accelerometer Module for Arduino
TRONIC.LK Item List 1-100
Post by TRONICLK » Mon Mar 11, 2019 3:47 am
