10 K 1/8W Resistor 1%
12 K 1/8W Resistor 1%
15 K 1/8W Resistor 1%
18 K 1/8W Resistor 1%
20 K 1/8W Resistor 1%
22 K 1/8W Resistor 1%
27 K 1/8W Resistor 1%
30 K 1/8W Resistor 1%
33 K 1/8W Resistor 1%
47 K 1/8W Resistor 1%
56 K 1/8W Resistor 1%
68 K 1/8W Resistor 1%
100 K 1/8W Resistor 1%
120 K 1/8W Resistor 1%
200 K 1/8W Resistor 1%
240 K 1/8W Resistor 1%
270 K 1/8W Resistor 1%
300 K 1/8W Resistor 1%
330 K 1/8W Resistor 1%
360 K 1/8W Resistor 1%
470 K 1/8W Resistor 1%
510 K 1/8W Resistor 1%
680 K 1/8W Resistor 1%
1 M 1/8W Resistor 1%
1.2 M 1/8W Resistor 1%
3.3 M 1/8W Resistor 1%
4.7 M 1/8W Resistor 1%
6.8 M 1/8W Resistor 1%
10 K Potentiometer 3X3 5%
0 Ohm 1/8W Resistor
43 K 1/8W Resistor 1%
360 Ohm 3/4W Resistor 5%
22 Ohm 1/8W Resistor 1%
5 Ohm 1/8W Resistor 1%
10 K Variable Resistor Preset
50 K Variable Resistor Preset
100 K Variable Resistor Preset
10 K Cermet Potentiometer Trimpot Trimmer 3296W
10 K Cermet Trimmer Pot Potentiometer
100K Volume Control
LDR 4mm
LDR 12mm
100uH Inductor 101 (12 x 12 x 7 mm)
ImH Radial Inductor (8 x 10mm)
20 MHz Crystal Oscillator
12 MHz Crystal Oscillator
16 MHz Crystal Oscillator
14.7456 MHz Crystal Oscillator
8 MHz Crystal Oscillator
4 MHz Crystal Oscillator
32.767 KHz Crystal Oscillator
TP4056 5V 1A Mini USB 18650 Lithium Battery Charging Module
TP4056 5V 1A Micro USB 18650 Lithium Battery Charging Module
1.5V AA Battery
1.5V AAA Battery
3V Battery CR2025
3V Battery CR2016
3V Battery CR2032
3.7V 1000mAh Lipo Battery
6V 4A Rechargeable Battery 70x46x99mm
9V Battery Normal
12V Battery GP 23A
12V 3000mAh Rechargeable Lipo Battery
12V 1500mAh Rechargeable Lipo Battery
12V 7Ah Rechargeable Battery 151x65x94mm
9V Battery Clip Snap Connector
Battery Terminal Set 6V and 12V
Battery Holder Case for 2xAA
Battery Holder Case for 4xAA
Battery Holder Socket for 2032 3V Cell Coin
Battery Holder Case 1-Way 23A/A23
XL4015 4V-38V to 1.25V-36V 5A DC to DC Step-Down Buck Adjustable Power Supply Module
LM2596S 3-40V to 1.5-35V 4A DC to DC Adjustable Step-Down Buck Module
PFM Control DC USB 0.9V 5V to 5V DC Boost Step-up Power Supply Module
MB102 5V 3.3V USB Type-A Breadboard Power Module
MB102 5V 3.3V Mini USB Breadboard Power Module
Hi-Link HLK-PM01 220VAC to 5VDC Step-Down Power Supply Module
4.5Vx2 300mA Transformer
6V 300mA Transformer
6Vx2 300mA Transformer
6Vx2 500mA Transformer
9V 300mA Transformer
9Vx2 300mA Transformer
9Vx2 400mA Transformer
9Vx2 500mA Transformer
9Vx2 800mA Transformer
9V 1000mA Transformer
9Vx2 1000mA Transformer
12V 300mA Transformer
12Vx2 300mA Transformer
12Vx2 400mA Transformer
12Vx2 500mA Transformer
12V 1000mA Transformer
12Vx2 1000mA Transformer
15V 300mA Transformer
24V 1000mA Transformer
24Vx2 1000mA Transformer
24Vx2 / 12V 3000mA Transformer
- It is currently Wed Nov 11, 2026 5:26 am
TRONIC.LK Item List 701-800
Post by TRONICLK » Mon Mar 11, 2019 3:52 am
