How to open folder using VB6
Posted: Mon Oct 31, 2011 3:02 pm
Option Explicit
Private Type BrowseInfo
hwndOwner As Long
pIDLRoot As Long
pszDisplayName As Long
lpszTitle As Long
ulFlags As Long
lpfnCallback As Long
lParam As Long
iImage As Long
End Type
Private Const BIF_RETURNONLYFSDIRS = 1
Private Const MAX_PATH = 260
Private Declare Sub CoTaskMemFree Lib "ole32.dll" (ByVal hMem As Long)
Private Declare Function lstrcat Lib "kernel32" Alias "lstrcatA" (ByVal lpString1 As String, ByVal lpString2 As String) As Long
Private Declare Function SHBrowseForFolder Lib "shell32" (lpbi As BrowseInfo) As Long
Private Declare Function SHGetPathFromIDList Lib "shell32" (ByVal pidList As Long, ByVal lpBuffer As String) As Long
Public Function BrowseForFolder(hwndOwner As Long, sPrompt As String) As String
'declare variables to be used
Dim iNull As Integer
Dim lpIDList As Long
Dim lResult As Long
Dim sPath As String
Dim udtBI As BrowseInfo
'initialise variables
With udtBI
.hwndOwner = hwndOwner
.lpszTitle = lstrcat(sPrompt, "")
.ulFlags = BIF_RETURNONLYFSDIRS
End With
'Call the browse for folder API
lpIDList = SHBrowseForFolder(udtBI)
'get the resulting string path
If lpIDList Then
sPath = String$(MAX_PATH, 0)
lResult = SHGetPathFromIDList(lpIDList, sPath)
Call CoTaskMemFree(lpIDList)
iNull = InStr(sPath, vbNullChar)
If iNull Then sPath = Left$(sPath, iNull - 1)
End If
'If cancel was pressed, sPath = ""
BrowseForFolder = sPath
End Function
Private Sub cmdServerBrowse_Click()
txtDatabasePath.Text = BrowseForFolder(hwnd, "Please select a Server folder.")
End Sub
