Public Function uAdd(ByVal A As Long, ByVal B As Long) As Long
Dim lOr As Long, lAnd As Long, P As Long
lOr = (A Or B) And &HC0000000
If lOr Then 'it might overflow
lAnd = (A And B) And &HC0000000
P = (A And &H3FFFFFFF) + (B And &H3FFFFFFF)
Select Case lAnd 'the last two bits common to both numbers
Case 0&
If (P And lOr) Then
If lOr < 0 Then uAdd = (P And &H3FFFFFFF) Else uAdd = (P And &H3FFFFFFF) Or &H80000000
Else
uAdd = P Or lOr
End If
Case &H80000000: If (P And lOr) Then uAdd = (P And &H3FFFFFFF) Or &H80000000 Else uAdd = P Or (lOr And &H40000000)
Case &H40000000: If (lOr < 0) Then uAdd = P Else uAdd = P Or &H80000000
Case Else: uAdd = P Or &H80000000
End Select
Else 'it won't overflow
uAdd = A + B
End If
End Function
Public Function uMult(ByVal A As Long, ByVal B As Long) As Long
'Unsigned 32bit integer multiplication with signed 32bit numbers
'Returns a signed 32bit number as if it were unsigned.
'Will overflow without error
'It might look ugly, but it's much faster than converting Longs to Doubles and back (when compiled)
Dim A1 As Long, A2 As Long
Dim B1 As Long, B2 As Long
Dim P As Long, P2 As Long
A1 = A And &H7FFF&
B1 = B And &H7FFF&
A2 = (A And &H3FFF8000) \ &H8000& 'quicker than... (A \ &h8000&) And &H7FFF&
B2 = (B And &H3FFF8000) \ &H8000& 'quicker than... (A \ &h8000&) And &H7FFF&
'multiply first 2 bits of A by last 2 bits of B
Select Case B And &HC0000000
Case 0&
Case &H40000000
Select Case A And 3&
Case 0&:
Case 1&: P = &H40000000
Case 2&: P = &H80000000
Case 3&: P = &HC0000000
End Select
Case &H80000000
If A And 1& Then P = &H80000000
Case Else
Case 0&:
Case 1&: P = &HC0000000
Case 3&: P = &H40000000
End Select
End Select
'multiply first 2 bits of B by last 2 bits of A
Select Case A And &HC0000000
Case 0&
Case &H40000000
Select Case B And 3&
Case 0& 'P+0
Case 1&: If P And &H40000000 Then P = P Xor &HC0000000 Else P = P Or &H40000000 'P+&H40000000
Case 2&: P = P Xor &H80000000 'P+&H80000000
Case 3&: If P And &H40000000 Then P = P Xor &H40000000 Else P = P Xor &HC0000000 'P+&H40000000+&H80000000
End Select
Case &H80000000
If B And 1& Then P = P Xor &H80000000 'P+&H80000000
Case Else
Case 0& 'P+0
Case 1&: If P And &H40000000 Then P = P Xor &H40000000 Else P = P Xor &HC0000000 'P+&H40000000+&H80000000
Case 3&: If P And &H40000000 Then P = P Xor &HC0000000 Else P = P Or &H40000000 'P+&H40000000
End Select
End Select
'multiply bits 16 and 17 of A and B
Select Case (A2 * B2) And &H3&
Case 0& 'P+0
Case Else: If P And &H40000000 Then P = P Xor &H40000000 Else P = P Xor &HC0000000 'P+&H40000000+&H80000000
End Select
'multiply first 15 bits of A and B
P = (A1 * B1) Or P
'multiply first 15 bits of A with bits 16 to 30 of B
P2 = A1 * &H2&
If P2 And &H10000 Then P2 = ((P2 And &HFFFF&) * &H8000&) Or &H80000000 Else P2 = (P2 And &HFFFF&) * &H8000&
P = uAdd(P, P2)
'multiply first 15 bits of B with bits 16 to 30 of A
P2 = A2 * &H1&
uMult = uAdd(P, P2)
End Function
