The nitty-gritty of writing a Binary file is that you can put the data into the file any way you want. When a binary file is opened the file pointer is positioned at byte 1. In other words it is at the beginning of the file.
You can write as much as you want into the file while it is open. After each write operation is complete, the file pointer is positioned at the byte immediately after the last data that was written.
For example, if you open the file and write 10 bytes of data, the data begins at byte 1 and ends at byte 10. The pointer is now at byte 11. You can change the pointer in code but that's where it will be if you do nothing. The same thing occurs when reading the file. If you close the file with no further writes to it then the subsequent file will be 10 bytes plus the size of a terminator for each piece of data you stored.
One thing that makes Binary access superior to Random access files is that the string fields can be any length at all. Strings are Visual Basic's largest data type not including objects or User Defined Types. They will quickly eat up memory and disk space, so it's nice to be able to store only as many characters as necessary.
For example, a Random access file must be written using fixed-length records as follows:
Option Explicit
Private Type tType
ID As Long
Name As String * 25
Address As String * 50
City As String * 25
State As String * 2
ZIP As String * 10
End Type
For Binary access we don't need to define the length of the string. If the string is 0 bytes, then 0 bytes get stored (plus some overhead to define the field as a string). The overhead also is used in Random access files, so on that level the files are the same.
Option Explicit
Private Type tType
ID As Long
Name As String
Address As String
City As String
State As String
ZIP As String
End Type
Writing a Binary File in its Simplest Form
Sub WriteBinaryFile ()
Dim i As Integer
Dim nFileNum As Integer
Dim sFilename As String
sFilename = "C:\Temp\Temp.dat"
' Get an available file number from the system
nFileNum = FreeFile
' Open the file in binary mode. Locks are optional
Open sFilename For Binary Lock Read Write As #nFileNum
' Put the data in the file
For i = 0 To 9
' No byte position is specified so writing begins at byte 1
Put #nFileNum, , i
Next i
Close #nFileNum
End Sub
' Reading the same file
Sub ReadBinaryFile ()
Dim iValue() As Integer
Dim iCount As Integer
Dim x As Integer
nFileNum = FreeFile
' Get the data from the file
Do Until EOF(nFileNum)
' Make room in the array for the next value
Redim Preserve iValue(iCount)
' No byte position is specified so reading starts at byte 1
Get #nFileNum, , iValue(iCount)
' Increment counter
iCount = iCount + 1
Loop
Close #nFileNum
End Sub
If we want our file to really be flexible then we probably won't be storing data that is always the same size and type. What if we want to store some byte data, a few records, an array of doubles as well as copyright information? We need a way to define what's in the file and the best place to put that information is in the file itself.
For VB DB, I created a header that contains descriptive information. If the file only contained one type of record and nothing else, then there is no need to save the number of records. We would just loop through the file until there was no more data. However, if there is more than one type of data then we need to know when to stop reading a data type and start reading another. This is much easier to accomplish than you might imagine.
The first record stored in the file is the header. Simply create fields in the header to save information about what's in the file.
For example if you wanted to store three different kinds of UDT's, then you would have three RecordCount fields. Each field would save the number of records in each array of UDT's.
When the file is read these numbers are extracted from the header and you've got all the information you need to read the rest of the file.
For VB DB, there are three pieces of information stored in the file. We already talked about the header being the first data written. Next are the field definitions.
Field definitions specify what data type each field is as well as other information that should be obvious by looking at the type. The last things stored in the file are the actual records.
In Practice
The first step is to define what will be saved in the file:
' Header definition
Private Type tHeader
VersionString As String
VersionNumber As String
RecordCount As Long
MaxRecordID As Long
End Type
Private Header As tHeader
' Field definitions. One field definition record is saved for each field
Private Type tFieldDefinition
Index As Long
SystemField As Boolean
FieldName As String
ArrayField As Boolean
DataType As Long
DefaultValue As Variant
Required As Boolean
RequireUniqueEntry As Boolean
End Type
Private m_FieldDefinitions(FIELD_INDEX_MAX) As tFieldDefinition
' The records
Private Type tRecord
Field(FIELD_INDEX_MAX) As Variant
End Type
Now let's look at how the file is written: Note: error handling code is not shown here for brevity.
Private Function Read(sFilename As String) As Long
Dim i As Long
Dim nReturn As Long
' Open the file
nFileNum = FreeFile
' Retrieve header
Get #nFileNum, 1, Header
' Size the array to hold the records
ReDim arr_Record(Header.RecordCount - 1)
' Retrieve the field definitions
Get #nFileNum, , m_FieldDefinitions
' Retrieve the records
For i = 0 To Header.RecordCount - 1
Get #nFileNum, , arr_Record(i)
Next i
' Close the file
Close #nFileNum
End Function
Private Function WriteFile() As Long
Dim i As Long
On Error GoTo errHandler
' Delete contents of Filename because the entire file is in memory
nFileNum = FreeFile
Open Filename For Output As #nFileNum
Close #nFileNum ' Close the file before opening in Binary mode
' Open the file
nFileNum = FreeFile
Open Filename For Binary Lock Read Write As #nFileNum
' Save header information
Put #nFileNum, 1, Header
' Save field definitions
Put #nFileNum, , m_FieldDefinitions
' Save records
For i = 0 To RecordCount - 1
Put #nFileNum, , arr_Record(i)
Next i
' Close the file
Close #nFileNum
End Function
In practice, VB DB provides a great deal of functionality to protect data, such as creating a backup file before saving. The backup file is restored if an error occurs when writing the file assuming the program didn't quit. If that happens then the backup is still on disk where it was created.
Ultimately what compels me to use binary file storage is flexibility to save what I want, how I want and that it uses disk space efficiently. You can store whatever you want and because you know how you stored it, you can retrieve it.
