my PC's screen has moved to right
Post by Rksk » Tue Dec 06, 2011 10:02 pm
I used a CRT monitor before. But last month it got a trouble and it was hard to find it's fault.
So I found another one to use till I repair my old CRT.
New one is a LCD. After connecting it to my pc, it worked charm with 1024x768 screen resolutions (its max).
After some days i got below problem after restart PC.
monitor error.JPG (32.34 KiB) Viewed 7955 times
then I opened dispaly settings,oh! there are only two screen resolution points now 800x600 & 1024x768.
I selected 800x600, dispaly came back to normal position. But it's still occurs with 1024x768.
Please help me.
Nandika
Re: my PC's screen has moved to right
Post by Nandika » Wed Dec 07, 2011 7:45 am
you can try from several system for solve this.
1.if u have warranty,try it
2.repair windows.
3.try with ur LCD menu.it may have a preset for horizontal moveing.
4.in ur LCD will have a small switch.you can find it and change it(if you do this,be very carefull).
i think system 2 is good.plz tell me,result.
good luck
Post by Saman » Wed Dec 07, 2011 5:42 pm
Some video display drivers allow you to move the screen either horizontally or vertically. You can try that. Also, as Nandika stated some monitors/LCD displays support the same through menu. Hope this helps!
Post by Rksk » Thu Dec 08, 2011 3:50 pm
Oh! I forgot that.
Thankz both.
Return to “???????? ?????”
