What is ASCILL? Do you mean ASCII - American Standard Code for Information Interchange ? Or something you have in J2ME? I know Java but not worked with J2ME.but there is a problem with ASCILL and CHAR functions
This question has no meaning. You try to get my point. First thing is you didn't read my answers clearly or your didn't understand. Here I'm telling you again.I think, creating a new FONTimage for unicode charactors is easy.
Drawing a new font is not a hard job. You will have to draw characters for the whole alphabet.
Once the characters are drawn, each is called a Glyph. A collection of glyphs can be used to create either an ASCII font or a UNICODE font.
For example, if you have drawn the glyphs for sinhala language, you can create an ASCII font. You need to consider fitting the number of glyphs you have within a total of 255 (including numbers and special symbols which must be there). This is not possible for a language like Sinhala. In good old days, we have put those glyphs in two ASCII font files. Kandy and Kandy Supplement are such two TTF files of the same font.
After the introduction of UNICODE, Sinhala was regarded as a world language and given a large range to store glyphs. Read my article on that. So if you are going to put your glyphs inside a UNICODE font, you will have to place them in the right places of the UNICODE font as specified by the UNICODE standard. You can't place them according to your wish as in ASCII where you can place anywhere you want.
For example: The Sinhala letter ? can only be placed at the location 0DC3 of a UNICODE font.
So, creating glyphs (you mentioned as font images) for either ASCII or UNICODE Font has equal effort as long as the number of glyphs you draw is the same.
Are you talking about functions in J2ME that are used to do operation on ASCII characters?but there is a problem with ASCILL and CHAR functions with Unicode charactors.
For sure, you can't use these for UNICODE. Read my text to understand that ASCII font can't carry more than 255 glyphs where as a UNICODE font can carry 65536 glyphs. So there must be a separate set of function for UNICODE.
This is the question that showed me you didn't read anything of my posts.is there any way to get ASCILL of a unicode charactor in PHP or JAVA?
Okay, I still like to explain you
On UNICODE, Sinhala language has its reserved area from 0D80–0DFF. Each number is mapped specifically for 1 character as said before. For example UNICODE ? is 0DC3. You can''t change this.
So you understand ASCII and UNICODE are completely two different things. You can't link them to map native languages to ASCII. There is no way to map. In other words, there is no special location for letter ? in ASCII where in UNICODE it is 0DC3.
So it is not even possible to write a function for this regardless of the language.
Since I know what you are going to do, I see a small picture which you can do this quite easily.
- Download the web page to your system (This is called scraping). Say you get FF FE C3 0D B8 0D B1 0D BD 0D BA 0D CF 0D for "Samanalaya" as in my last post.
- Decode the UNICODE string
- Remove BOM (FFFE)
- Then decode each pair of bytes (Ex: 0D C3, in HEX two positions represent 1-byte)
- Map UNICODE to your PNG images
Now what is 0DC3 - This is a number in HEX. In decimal, this is 3523.
So whenever you get 3523 (0DC3), you point to letter ? in your PNG image and draw it.
So what you have to make is a lookup table to map all these UNICODE numbers to your PNG image.
First thing is to concentrate on learning the theory. Don't try to push yourself too much on doing it in your own way when the things are already invented. Otherwise what you are trying is to invent the wheel at a time the world has sent satellites to the moon
