How to control a Stepper Motor using ULN2003 & microcontror
Posted: Fri Jun 24, 2011 9:11 pm
by Shane
This page shows an example on how to drive a unipolar stepper motor. These motors can be found in old floppy drives and are easy to control. The one we use has 6 connectors of which one is power (VCC) and the other four are used to drive the motor sending synchronous signals.
ULN2003A driver chip has a bunch of transistors embedded in a single housing. It allows the connection of devices and components that need much higher current.
//This example demonstates the use of the ULN2003 to drive a stepper motor.
 //The speed and direction of the stepper motor is determined by adjusting
 //the potentiometer connected to A2. When the potentiometer is rotated fully
 //counterclockwise, the motor will rotate at full counterclockwise speed. As
 //the potentiometer is rotated clockwise, the motor will continue to slow down
 //until is reaches its minimum speed (when the potentiometer is at the middle
 //position.) Once the potentiometer crosses the middle position, the motor will
 //reverse direction. As the potentiomer is rotated further clockwise, the speed
 //of the motor will increase until it reaches its full clockwise rotation speed
 //when the potentiometer has been rotated fully clockwise.
 //declare variables for the motor pins
int motorPin4 = 5;
 int motorPin3 = 6;
 int motorPin2 = 7;
 int motorPin1 = 8;
int motorSpeed = 0; //variable to set stepper speed
 int potPin = 2; //potentiometer connected to A2
 int potValue = 0; //variable to read A0 input
 void setup() {
 //declare the motor pins as outputs
 //int potValue = potValue*2;
 pinMode(motorPin1, OUTPUT);
 pinMode(motorPin2, OUTPUT);
 pinMode(motorPin3, OUTPUT);
 pinMode(motorPin4, OUTPUT);
 Serial.begin(9600);
 void loop(){
 potValue = analogRead(potPin); //read the value of the potentiometer
 Serial.println(potValue);//View full range from 0 - 1023 in Serial Monitor
 if (potValue < 511){ //if potentiometer reads 0 to 511 do this
 motorSpeed = (potValue/15 + 8); //scale potValue to be useful for motor
 clockwise(); //go to the ccw rotation function
 else { //value of the potentiometer is 511 - 1023
 motorSpeed = ((1023-potValue)/15 + 8); //scale potValue for motor speed
 counterclockwise(); //go the the cw rotation function
 //set pins to ULN2003 high in sequence from 1 to 4
 //delay "motorSpeed" between each pin setting (to determine speed)
void counterclockwise (){
 digitalWrite(motorPin1, HIGH);
 digitalWrite(motorPin2, LOW);
 digitalWrite(motorPin3, LOW);
 digitalWrite(motorPin4, LOW);
 delay(motorSpeed);
 digitalWrite(motorPin1, LOW);
 digitalWrite(motorPin2, HIGH);
 delay (motorSpeed);
 digitalWrite(motorPin3, HIGH);
 delay(motorSpeed);
 digitalWrite(motorPin4, HIGH);
 delay(motorSpeed);
 //set pins to ULN2003 high in sequence from 4 to 1
void clockwise(){
 delay(motorSpeed);
 delay (motorSpeed);
 delay(motorSpeed);
 delay(motorSpeed);
Courtecy of UMASS AMHERST
