MT-87 Digital Clamp Clip-on Multimeter
AX-1838HS IR Receiver Module 38KHz 3-pin
Stepper Motor 28BYJ-48 5line 4phase 5V with ULN2003 Driver Module
3.7V 850mAh Lipo Battery
L298N Motor Driver Shield with Buzzer for Arduino
USB to ESP8266 ESP-01 Interface Module
L293D Push Pull Four Channel Motor Driver (Normal)
4V 400mA Battery 28x20x44mm (Normal)
4V 600mA Battery 28x19x52mm (Normal)
4V 1600mA Battery 36x27x80mm (Normal)
4V 1600mA Battery 49x21x75mm (Normal)
4V 2500mA Battery 49x21x98mm (Normal)
OTG Adapter
HDMI to VGA Adapter Cable (No Convertion)
HDMI to 3-RCA Cable
12VDC DS2Y-S-DC12V AGY2323 DPDT 1A Miniature Relay
TV Remote Control TOSHIBA CRT RM-162B
2N2222 Photodiode 3-pin
USB WIFI Dongle 150Mbps
USB Bluetooth Dongle
Pulse Rate Heartbeat Sensor Module for Arduino
ACS712 20A Current Sensor Module for Arduino
ACS712 30A Current Sensor Module for Arduino
ZMCT103C 5A Range AC Current Sensor Module for Arduino
TDA7297 Mini 15W Stereo Audio Amplifier Module 12V
LilyPad Main Board ATMega328
LilyPad Main Board ATMega32U4 with USB Port
Battery Holder Case for 1x18650
Battery Holder Case for 2x18650
STK4152 Stereo Amplifier Board QR322
2SD1047 Stereo Amplifier Board Transistor AV228
VGA Switch 2-way Wide Screen
TTP223 1-Channel Digital Capacitive Touch Sensor Module
SIM Card Socket Tray Type SMD PCB Mount
E27 Screw Type Holder (Normal)
MicroSD Card Reader USB 2.0
Samsung Phone Charger 5V 2A (Good Quality)
LED 1W High Power Blue
LED 1W High Power Green
Omron MY3N-J 12VDC 5A 240VAC 28VDC 11pin Electromagnetic Relay
Omron MY3N-J 240VAC 5A 240VAC 28VDC 11pin Electromagnetic Relay
Dual Female Banana Plug Terminal Binding Post for Speaker Amplifier Stereo
Stereo Male to Dual Female Stereo Y Splitter Audio Adapter 3.5mm
Stereo Jack Mic 6.5mm (Good Quality)
RCA Jack Red (Good Quality)
RCA Jack Black (Good Quality)
LED UV Ultraviolet 390 to 395nm Purple Lamp
5VDC DS2Y-S-DC5V AGY2329 DPDT 1A Miniature Relay
Push On/Off Switch Round Plastic Yellow
Push On/Off Switch Round Plastic Blue
Push On/Off Switch Round Plastic Green
Push On/Off Switch Square Plastic Black
Push On/Off Switch Square Plastic Green
Push On/Off Switch Square Plastic Blue
Push On/Off Switch Square Plastic Yellow
Rain Water Level Sensor Depth Detection for Arduino
Multifunctional Expansion Shield For Arduino
4x4 Matrix Array Keypad Switch Module for Arduino
TCS230 Colour Recognition Sensor Module for Arduino
MQ-7 Carbon Monoxide CO Gas Sensor Module Type 1
MQ-214 Methane Gas Sensor (Only Sensor)
SCT-013-030 Non-invasive 30A AC Current Clamp Sensor
Mini Project Board Breadboard Solderless White (45x35x10mm)
Mini Project Board Breadboard Solderless Red (45x35x10mm)
Mini Project Board Breadboard Solderless Orange (45x35x10mm)
HZ21WA Water Flow Sensor 1-30L/min 1.75MPa 0.5inch
S201C Water Flow Sensor 1-30L/min 1.75MPa 0.5inch
JF-0530B Pull-Push-Type Solenoid Switch 12VCD 300mA 5N/10mm
99-S12 Solenoid Door Lock 12VDC
SON-FB Universal Fan Controller with Remote
Tweezer Metal Non-magnetic Straight Long TS-11 (Normal)
Tweezer Metal Non-magnetic TS-10 (Normal)
Tweezer Metal Non-magnetic Straight ST-11 (Good Quality)
Tweezer Metal Non-magnetic Curve ST-15 (Good Quality)
Line Hunting Sensor Module with Preset 4-pin TCRT5000 for Arduino
Smart Card NFC 13.56MHz Read Write RFID IC
Smart Card ISO PVC IC SLE4442 Chip
33 Ohm 1W Resistor 5%
5.6 Ohm 1W Resistor 5%
330 Ohm 1W Resistor 5%
LA78040 TV and CRT Display Vertical Output IC
2SC1845 NPN Silicon Transistor
Type C USB Data Cable Normal for Samsung
Caster Wheel Plastic Ball 25.4mm
Adjustable Transformer Power Supply 1.5V-12V 1A YB328
Micro USB to USB3.1 Type C Charger Adapter Convertor
5x7 LED Matrix Red Common Cathode 2 inch
Car Charger USB Dual Output 2.1A with Cable DL-219 (Good Quality)
Car Charger USB Single Output 1A with Cable DL-C17 (Good Quality)
USB HUB 4-port 1.2m Cable USB3.0
VCD DVD TV Power Module Repair Board 14-34" QH-34C
2SC2240 Transistors
TNY279 AC/DC Converter
100uF 100V Capacitor
6A10 Diode
TDA2003 10W Car Radio Audio Amplifier
Buzzer Module (Small) for Arduino
Voice Sound Detection Mic Sensor Module for Arduino
LM393 Light Sensor Module for Arduino
LDR Light Sensor Module for Arduino
- It is currently Sun Sep 27, 2026 5:53 am
TRONIC.LK Item List 1601-1700
Post by TRONICLK » Mon Mar 11, 2019 4:17 am
