IBM PC 350 power supply
tmadushan
Sergeant
Sergeant
Contact:
Post by tmadushan » Thu Oct 04, 2012 11:31 am
Friends, I want to make a bench power supply from my old IBM PC 350 100W PSU. Can u help me on finding the Voltages and wires corresponding to them??
Tharanga
Re: IBM PC 350 power supply
Post by Neo » Thu Oct 04, 2012 12:02 pm
See this site: http://www.playtool.com/pages/psuconnec ... ctors.html
Also, you might be able to beautify your power supply as below :)
tmadushan
Sergeant
Sergeant
Contact:
Post by tmadushan » Thu Oct 04, 2012 5:01 pm
Thanks a lot NEO, but I couldnt find the exact wire connections for POWER_ON, Power indicator.. etc.
Please help me in finding those connectors too.
Post by Neo » Thu Oct 04, 2012 6:29 pm
Is this ATX or AT?
AT comes with a switch where ATX is powered from mother board.
tmadushan
Sergeant
Sergeant
Contact:
Post by tmadushan » Fri Oct 05, 2012 8:24 am
Could be AT bcz its a very old one. 1996 I think....
IBM P/N= 0H8823
Post by Neo » Fri Oct 05, 2012 11:34 am
Then it should have the power button connected directly to the unit. On AT PSUs, the power is on by the user, not from the motherboard. So what you have to do is, trace where you unplugged the cables and find the connection from power on/off switch to the motherboard. There should be 4 wires going to the power button in the casing.
tmadushan
Sergeant
Sergeant
Contact:
Post by tmadushan » Fri Oct 05, 2012 5:29 pm
OMG, That would be something really hard... Isnt it?
Post by Neo » Fri Oct 05, 2012 5:51 pm
If it is AT (not ATX) then the CPU is powered with a switch directly connected to the PSU. Can you tell me what type of switch you have on the CPU? Is it a press type (just a little micro switch is there) or a push type (push to make, push to break type)? We need to clarify your PSU type clearly here. Since AT and ATX are totally different systems without knowing the exact model, it would be hard as you thought. If it is AT, there should be a switch going to PSU directly. If not (ATX), it would be powered from mother board and you will find the power button of the casing going straight to motherboard.
tmadushan
Sergeant
Sergeant
Contact:
Post by tmadushan » Fri Oct 05, 2012 6:14 pm
Its an AT PSU with push type switch
Post by Neo » Fri Oct 05, 2012 6:29 pm
Okay, so power button is there. Why don't you carefully connect 230 A/C and check the P8 and P9 cables for the power lines you need now ? ;)
