If you have bought a MPU-6050 module from TRONIC.LK, here is quick guide to get you started.
The MPU-6050 is a serious little piece of motion processing tech! By combining a 3-axis gyroscope and a 3-axis accelerometer on the same silicon die together with an onboard Digital Motion Processor™ (DMP™) capable of processing complex 9-axis MotionFusion algorithms, the MPU-6050 does away with the cross-axis alignment problems that can creep up on discrete parts.
Datasheet:
http://dlnmh9ip6v2uc.cloudfront.net/dat ... -6000A.pdf
Lib with example source:
Another example:
- It is currently Wed Nov 11, 2026 7:27 pm
How to interface MPU-6050 to Arduino
