Commented codes are not getting executed in php.mysoogal wrote:thanks again, i thought when you add // blaaa blaa in php it doesnt get executed
If you are not going to use IDX, then you need to remove that from the function as well.
To be sure, I'll paste the code without using idx.
<?php
$dir = './'; // set to current folder
if ($handle = opendir($dir)) {
while(false!== ($file = readdir($handle))) {
if ( is_file($dir.$file) ){
if (preg_match("'\.(avi)$'", $file) ){
$sub_file = str_ireplace(".avi", ".srt", $dir.$file);
$thumb_file = str_ireplace(".avi", ".jpg", $dir.$file);
$out_file = str_ireplace(".avi", ".mp4", $dir.$file);
flv_convert_get_thumb($dir.$file, $sub_file, $thumb_file, $out_file);
else{
continue;
closedir($handle);
//flv_convert_get_thumb('input.avi', 'input.srt', 'output.jpg', 'output.ogm');
// code provided and updated by steve of phpsnaps ! thanks
// accepts:
// 1: the input video file
// 2: path to thumb jpg
// 3: path to transcoded mpeg?
function flv_convert_get_thumb($in, $in_sub, $out_thumb, $out_vid){
// get thumbnail
$cmd = 'ffmpeg -v 0 -y -i '.$in.' -vframes 1 -ss 5 -vcodec mjpeg -f rawvideo -s 286x160 -aspect 16:9 '.$out_thumb;
$res = shell_exec($cmd);
// $res is the output of the command
// transcode video
$cmd = 'mencoder '.$in.' -o '.$out_vid.' -sub '.$in_sub.' -subfont-text-scale 3.3 -subpos 96 -af volume=10 -aspect 16:9 -of avi -noodml -ovc x264 -x264encopts bitrate=500:level_idc=41:bframes=3:frameref=2: nopsnr: nossim: pass=1: threads=auto -oac mp3lame';
